Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression calculator
Old 02-16-2006, 12:25 PM
mstngjoe's Avatar
mstngjoe mstngjoe is offline
Originally Posted by camaroman7d
9:1 with iron heads should not be a problem. 10:1 is the "rule of thumb limit" for iron heads and pump gas. If your quench is tight you should have no problems with 9:1 on pump gas w/iron heads.
Royce
I would agree with this.......and quench is a very important factor.
