Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compression Calculator Help
Old 11-14-2012, 12:20 PM
MouseFink MouseFink is online now
Originally Posted by allansmith859 View Post
So when I bought my gaskets it says on the box/package what the compressed thickness is??? Also I have flat top pistons and around the outter edge of it its slightly higher than in the middle of it. So should I measure from the center of the piston or from the edge of the piston
The Fel Pro gaskets I have used had the crushed thickness on the container or instruction sheet. The composition (sandwich) gaskets are usually from .039" to .041" crushed thickness. The razor or shim gaskets do not have a crushed thickness. The crushed thickness of a composition gasket cannot be measured and that is why it is provided on the container.
It appears that you have dished pistons. What are you trying to measure?
