Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compression Calculator Help
  #20 (permalink)
Old 11-16-2012, 04:52 AM
allansmith859 allansmith859 is offline
Tech Inspector you the man. Gotta a question for u. I dont know a hole lot about performance parts but Im trying like hell to learn. Anyway those KB pistons you showed ( are those strictly designed to raise compression ratios. Correct me if Im wrong, do they make the so called dome, raised so there is less area in the combustion chamber therfore creating more compression??
