Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compression fittings on brake lines
Old 06-23-2004, 11:54 AM
Chev283's Avatar
Chev283 Chev283 is offline
Last journal entry: As of about 4/2004
Ditto on the replacement of the line. Compression fittings are only good for small water lines around the house, or for connecting mechanical gauges on your car.
Buy the pre-flared tubing at NAPA, and put a new piece in there. They sell it in various lengths up to 40". If you need a longer piece just join them together with brass inverted flare female connectors. You always need a double flared piece of steel tubing for brake lines, and the ones from NAPA are that way. If you buy un-flared tubing or cut a piece, you will need a double flare tubing kit to flare your own.
Good luck
Chev283
