compression gauge - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2008, 10:17 AM
FEDDO's Avatar
compression gauge
I have tried 4 different gauges, 2 new, and 2 that I have. all are varing quite a bit from one I borrowed a month ago. any suggestions? one fron sears, one from o'rileys and the 2 i have in the shop are ones I have had for yrs. they are varing, by up to 30 lbs.
Old 11-02-2008, 10:27 AM
All you need to do is compare each gauge to a known accurate pressure gauge using a regulated constant pressure system, and then ****can the bad gauges.
Some of the bigger aircraft shops that are FAA Certified Repair Stations have calibration gauges.
added
OR you could just use your existing hose and buy a certified gauge from an aircraft place. This would probably be cheaper and less hassle.
Old 11-02-2008, 10:45 AM
FEDDO's Avatar
the obvious is right in ft of me. I just went out turned on my compressor, made a male to male adapter and found my 2 old gauges are near perfect. tomorrow ,will take my torque wrench and 2 comp gauges to the shop that certs my stuff, for non cert prices. i don't need the paper work. thanks Scott for the obvious. dumb ol man
gas gauge trouble cutsupreme Electrical 4 01-25-2008 09:40 AM
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 01:50 PM
Need help with fuel gauge Crazy-J Electrical 3 03-01-2005 11:46 AM
Possible for autometer temp gauge to be bad? fouroheight68 Engine 8 02-21-2005 11:20 AM
Twilight Zone and my temperature gauge unstable Engine 8 10-08-2003 03:57 PM
