Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression on my 383
Old 02-19-2003, 02:40 PM
nickel333 nickel333 is offline
with that little cam dont get compression too high or youll detonate. The only real way to check actual piston to valve clearance is to clay the pistons and do it manually. You must have a huge dish and some 76cc heads to get 8.8:1 man, are you sure about your current compression?? I have a calculator if you give me you head cc and the piston dish cc ill figure it out for you
