Compression numbers on a '70 250hp 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2011, 08:50 PM
I'm getting high numbers (highest i've ever gotten) on an unmodified 350. Lowest is 170 and highest is 179 averaging 174.5. The heads are 441s. I have read that these haeds are 76cc but I have also read that they could be 72cc. The motor has 104500 miles unrestored. It did run strong. Are the numbers high?
Old 11-02-2011, 09:17 PM
starnest's Avatar
elkyholic
Last journal entry: Center Link Installed
My '71 service manual for 245hp 350, 8.5:1 CR
160psi, cranking speed, wot, max variation 20psi
441 heads - 250hp, 1.94/1.50 valves, 76.26cc chambers
What do these numbers mean? Buckeye Bob Engine 1 08-12-2011 09:45 PM
compression ratio compared to compression PSI squids1 Engine 14 12-29-2010 12:36 AM
Engine casting numbers and vin numbers drfo Engine 5 06-18-2010 06:15 PM
interpreting compression numbers crownver Engine 7 03-22-2006 04:12 AM
250hp/327 heads 78 monte Engine 1 01-03-2005 01:57 PM
