compression ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2008, 01:31 AM
compression ratio
i have an old 350 block and a set of dished pistons. am wondering what comp ratio would be with 383 strocker crank, 5 3/4" rod and a set of vortec heads.
am looking for suggestions for a cam with big torque go to about 5500 rpm
any info would be great thanks tuk
Old 08-21-2008, 09:10 AM
vortec heads are 64cc. Look for a 383 piston for a 5.7 inch rod than makes around 9:1 cr. Get a D-shaped dish (cast hyper piston). Use a cam with around 210 to 215 degree on the intake at 0.050" and 8 to 10 more degrees on the exhaust (because vortec heads don't flow well on the exhaust port).
You will need a piston with a -22cc volume.
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Compression Ratio? 72chevyC/10 Engine 3 09-12-2005 04:21 PM
How to figure compression ratio...... classic_chevy_guy Engine 9 07-26-2005 09:59 PM
383 Chevy Compression Ratio? Skunk Engine 5 07-06-2005 07:07 AM
327 compression ratio dadsgp Engine 4 06-23-2005 08:42 PM
