Compression ratio? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-14-2011, 04:04 PM
ericnova72's Avatar
More for Less Racer
Originally Posted by MouseFink
5738 CC engine displacment
5738 / 8 = 717.25 CC cyl. vol.
717.2 CC / 85 CC chamber vol. = 8.44 : 1 CR
Assuming (without actual measurment):
64 CC combustion chamber vol.
+9 CC gasket, reliefs, deck vol.
+12 CC dish vol.
_______
85 CC total chamber vol.
That engine could run good on Cool Aid.
As usual, your wrong.
You did the math incorrectly. You have a 717.2cc cylinder volume and an 85cc chamber/gasket/deck height volume, but you forgot one step,... you have to add together the cylinder volume and the head chamber volume to get total volume, then divide by chamber volume.
So, 717.2 plus 85 equals 802.2, 802.2 divided by 85 equals 9.43 to 1 compression ratio...using the volume numbers you proposed for each component.
  #17 (permalink)
Old 02-14-2011, 09:19 PM
Madmax305's Avatar
Wow! You lost me at "SO", Can you speak english. LOL
  #18 (permalink)
Old 02-14-2011, 10:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
To put it simply, the compression ratio is the ratio between the cylinder volume w/the piston at BDC compared to the volume w/the piston at TDC. Or the ratio of the largest you can make the volume of a cylinder to the smallest volume you can make the cylinder.
As ericnova72 correctly pointed out, this ratio includes the combustion chamber volume in both sides of the equation.
To help visualize this, a simplified scenario might be:
Total volume at BDC of 1000cc
Volume at TDC is 100cc
The ratio of the smallest volume (at TDC) to the largest volume (at BDC) is 10:1.
Personally, I use an online calculator whenever possible. But if you want or need to do it longhand, TI has posted the formula in easy to understand language, HERE, post #8.
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Compression Ratio Help KillerK10 Engine 3 02-10-2010 05:02 PM
383 compression ratio? 72GMCTruck Engine 10 10-09-2008 06:14 AM
compression ratio 84 GMC Sierra Pickup Engine 9 10-25-2005 05:19 AM
compression ratio? Dans83Olds Engine 3 06-07-2003 06:49 PM
