Compression ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2011, 02:22 PM
Madmax305's Avatar
Compression ratio?
Hey guys, I have a GM performance 290hp motor with 72cc heads in my El Camino. It has 8.5 to 1 compression. A while back I replaced the heads with RHS Vortec with 64cc chambered heads. The stock pistons are flat tops? Can anybody give me any idea of my compression ratio with the RHS heads installed? The head gaskets were the ones RHS recommended, sorry that's all I know about the gaskets or the motor.
Old 02-13-2011, 02:29 PM
FastOrange's Avatar
my guess is like 10-10.5:1
Old 02-13-2011, 02:58 PM
bigdog7373's Avatar
Of course it's fast
I would say 10 or lower.
Old 02-13-2011, 03:55 PM
Pump gas
A engine with 10.5:1 CR is on the borderline of detonation when using 93 octane pump gas if the initial timing advance is set where the engine will run best. Aluminum heads can tolerate 1/2 to one point higher compression ratio than cast iron heads with the same combustion chamber volume. When the engine get some time on it, the problem with detonation on 93 octane pump gas will increase.
Rule of thnub is the first three numbers of your compression ratio indicates the minimum octane rating of the fuel that must be used. 9.3:1 CR = 93 octane, 10.5:1 CR = 105 octane, 11.0:1 CR = 110 octane, 12.0:1 = 120 octane
There is no scientific reason for it but that is just the way it is.
Old 02-13-2011, 05:51 PM
ericnova72's Avatar
More for Less Racer
Taking a rough stab at it using an online calculator and making an educated guess at some of the dimensions you don't have - 64cc head, 7cc valve relief, common .041" thick composition head gasket, and an undecked block which puts the piston .025" down the bore at TDC results in a 9.6-1 compression ratio.
I use the calculator at www.wallaceracing.com They have a huge calculators page
Old 02-13-2011, 05:56 PM
Madmax305's Avatar
Thanks for all the info guys. Thank you ericnova72 for the calculations. I was hoping for about 9.5 but 9.6 is even better.
Old 02-14-2011, 01:34 AM
Madmax305's Avatar
Originally Posted by F-BIRD'88
The GM 350 290Hp crate motor does not have flat top pistons
The pistons have a dish , approx dish volume is 12cc
if you were to shave the 64cc heads by .030" (59cc finished) and install with a .015" felpro 1094 gasket, you would have a true 10.00:1 cr.
So any guesstimate on my compression ratio with the above information?
Old 02-14-2011, 01:40 AM
SSedan64's Avatar
With Eric's Info and the 12cc Dish Pistons = 9.00:1Cr
No milling and a .015" Thick Shim Gasket = 9.50:1Cr
ericnova72's Avatar
More for Less Racer
Figuring with an undecked block so piston is down the hole at TDC .025", with .041" thick composition gasket, 64cc head and 12cc piston gives 9.1-1.
Calculator used is on Automotive Calculators page at www.wallaceracing.com
Old 02-14-2011, 01:43 AM
ericnova72's Avatar
More for Less Racer
Use of an .015" steel shim head gasket instead of the common .041 composition gasket will get you back to 9.6-1 with a 12cc dish and the 64cc head.
Old 02-14-2011, 01:49 AM
Madmax305's Avatar
Thanks for the quick replies. I was hoping it would be a bit higher, but 9.1-1 is not so bad with 91 octane.
Old 02-14-2011, 04:55 AM
SSedan64's Avatar
Does your 290HP Crate engine have a standard 4.00" Bore? If so that's why Eric's & my calculations differ by .10
I used a 4" Bore.
Old 02-14-2011, 11:25 AM
Madmax305's Avatar
I used a 4" Bore.
Yes, it has a 4.00 bore x 3.48 stroke.
Old 02-14-2011, 01:45 PM
Pencil and paper measument
5738 CC engine displacment
5738 / 8 = 717.25 CC cyl. vol.
717.2 CC / 85 CC chamber vol. = 8.44 : 1 CR
Assuming (without actual measurment):
64 CC combustion chamber vol.
+9 CC gasket, reliefs, deck vol.
+12 CC dish vol.
_______
85 CC total chamber vol.
That engine could run good on Cool Aid.
Old 02-14-2011, 02:42 PM
spinn's Avatar
When dealing in compression x power shown on a curve for a certain fuel, it violently curves up around 8.8:1 to 11.5 compression. Indicating a possibility, that there , lies the best compression ratio to extract power from a fuel source.
compression ratio compared to compression PSI squids1 Engine 14 12-29-2010 12:36 AM
Compression Ratio Help KillerK10 Engine 3 02-10-2010 06:02 PM
383 compression ratio? 72GMCTruck Engine 10 10-09-2008 07:14 AM
compression ratio 84 GMC Sierra Pickup Engine 9 10-25-2005 06:19 AM
compression ratio? Dans83Olds Engine 3 06-07-2003 07:49 PM
