compression ratio on 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2011, 02:16 PM
Can anyone tell me what compression ratio i'll get with +030 flat top pistons with 4V/R using 64cc heads? And roughly what horsepower it will have?
using a edelbrock performer plus cam.
Thanks
Old 03-22-2011, 10:39 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Use Summit's compression ratio calculator. Click this link, scroll down, click on the Compression Calculator link. OEM deck height is .025". Even if you have flat top pistons with valve reliefs, you need to add cc's. The 4 eyebrow relief style usually contains 4-6cc. OEM head gaskets are around .040" I believe.
http://www.summitracing.com/parts/FEL-1003/
Old 03-23-2011, 12:44 PM
Deck height .025. head thickness is .015. thanks
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
Calculate Compression Ratio for blown SB CHEVY? physcult Engine 40 08-15-2010 08:05 PM
Compression Ratio ? chevy350_Camd Hotrodding Basics 27 02-03-2008 08:09 PM
383 Chevy Compression Ratio? Skunk Engine 5 07-06-2005 07:07 AM
Compression ratio dubie Engine 3 06-25-2004 08:50 AM
