Compression Ratio with 64 cc heads & Federal Mogul Sterling 345np - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2005, 03:59 AM
Jeeps Are Us!
Last journal entry: The Paint Shop
Hi everyone!
Until now, I was almost sure that I'm having a 10:1 compression ratio for my new engine, but saw this thread which made me confused!!!
This guy had mentioned that with 64cc Vortec Heads and flat top pistons WITH NO valve relives he is making 10:1 compression.
But in Federal Mogul's catalogue, it says that 345np flat tops with four valve relives will produce 10.2:1 compression ratio when used with 64cc heads???
I'm exactly using Federal Mogul Sterling 345 np's with four valve relives + Edelbrock 64 cc heads and 0 deck.
What is finaly my compression ratio? Is it 10.2:1 as Federal Mogul declares?
Thanks for helping me out of this confusion.
Houman
Old 04-27-2005, 05:50 AM
DoubleVision's Avatar
Here`s where the fun part begins. The 345NP piston, is ".020 destroked" meaning, it has .020 off the top of the piston, where a normal 350 piston would have a 1.560 compression height, these have 1.540. so even with a zero deck height, it would still be .020 down in the hole. They really seem to go out of there way to hide this too, they don`t mention it anywhere on the box, and many sites on ebay list them as 1.560 compression height, but being they have .020 off the tops, this is why there so cheap. with a zero deck with these pistons and a 64cc head compression will likely come in around high 9:1 ratio, depending on what the head gasket thickness is.
Old 04-27-2005, 06:34 AM
Last journal entry: PICTURE TEST
compression
I do not have exact figures for this piston but i figured it out at..
Pistons.......4 cc with valve pockets
pistons down in the hole .020 = an additional 5cc's, assuming it is zero decked
head gasket 9.1 cc's
and 64 cc head. the edelbrocks that i have checked have been close to advertised volume.
So all that comes out to a static compression of 9.86:1
Keith
Old 04-27-2005, 08:10 AM
firestone's Avatar
http://teamrfc.gospelcom.net
I think k star is really close. I had a 355 with vortec heads, and flat top pistons with four valve releifs. It also had .050 quench. The shop that built it said that it had 9.89:1 static compression.
Adam
Old 04-27-2005, 09:01 AM
Jeeps Are Us!
9:1 or 9.8:1 Which is the correct Compression ratio?
Doublevision,
What do you say?
Old 04-29-2005, 12:59 AM
Federal-Mogul's website is claiming that the 345's now have 1.56" compression height. Wonder if anybody's measured?
Old 04-29-2005, 09:50 AM
coldknock's Avatar
It's a boo-boo. I have a brand new set here and from the center of the pin bore to the crown it measures 1.541"
Larry
King of my Man-cave.
The regular cast versions are 1.54". The hypereutectic versions are 1.56"
tom
Old 05-01-2005, 11:12 AM
Jeeps Are Us!
Tom,
I think it's the other way round, because if you look in Jeg's, h345 np which is the Hypereutectic is said to produce 9.5 with 64cc heads and 345npstd is said to produce 10.2.
This is what it says, do you think that now cast is 1.54 and hypereutectic is 1.56?
Kindly clarify and let me know how it should be.
Thanks,
Houman
Old 05-01-2005, 11:42 AM
coldknock's Avatar
The piston I measured at 1.541 is the regular cast version.
Larry
64 cc heads for 383 stroker.. chevtruck Engine 12 08-04-2008 08:44 AM
64 cc heads on a 383 Lthompson Engine 21 02-10-2005 09:49 PM
64 or ?? cc heads wickster Engine 10 01-10-2005 02:32 PM
351w Vance Perino Engine 11 08-06-2003 10:29 PM
Figuring Compression ratio with 66 cc heads Camaro2Fast4u Engine 4 01-31-2003 11:47 PM
