Compression Ratio for 74 ford 2.3 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2012, 05:09 PM
Last journal entry: Albany Oregon Show
Hi
I am going to put a cam in a 74 Ford 2.3. I have heard the compression ratio is 8.5 but am not sure. Does anyone know for sure what the cr is on this engine? The engine is in a 28 A roadster pickup.
B
Old 09-23-2012, 05:30 PM
Banned
you can mill a LOT of that head- enough to allow for any compression that your heart desires. I'd bump it up to about 9.7:1, pick up a ranger "header" manifold, and put in a cam with about 225/225 duration. It's a great combo using all stock parts- except the cam.
Old 09-23-2012, 09:16 PM
Thank you for that information. If anyone knows what ratio I am starting out with for sure it would also be helpful
B
Old 09-24-2012, 08:56 AM
Banned
B
actual vs "advertised" compression can vary quite a bit for older cars. just meausre your piston volume, deck clearance, gasket thickness, and head volume and calculate your own compression.
If you don't have a mic you can measure your volume above the piston by bringing it to TDC and sealing the edges with a thin layer of petroleum jelly. Use a common medical syringe to measure the volume- available at any corner drug store.
be sure to have it level and seal the top with either a hard plastic sheet or an old CD.
These are common cheap tricks that most of us use around here.
Old 09-30-2012, 06:08 PM
cal1320's Avatar
My 1981 chilitons book lists the comperssion for a 1974 Pinto at 8.4 to 1.
BTW, when you mill the head on a Pinto engine, you need an adjustable cam sprocket to correct the cam timing after the head mill.
Compression Ratio Burky Engine 5 10-28-2011 12:47 PM
Compression ratio? Madmax305 Engine 17 02-14-2011 11:46 PM
compression ratio compared to compression PSI squids1 Engine 14 12-29-2010 12:36 AM
compression ratio binderboy Engine 1 08-21-2008 10:10 AM
compression ratio tlibbin Engine 2 12-11-2001 10:12 PM
