compression ratio and fuel confusion - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2010, 02:12 PM
55effie's Avatar
Alright....I am confused as hell here. I just bought a 1955 F100 with a 383 stroker in it. It has a compression ratio of 10.5:1 with flat top pistons with six inch rods and 64CC heads with 200CC intake runners. On top is a 650 CFM Demon 4 barrel carb, and hydraulic lifters. I am not sure what the numbers on the cam are, and the previous owner cannot remember either, but it is rather steep.
I just had the Carb rejetted to match my elevation here in Colorado Springs of 6200 feet. THe new primaries are 65PPM. Here is where I am confused. It ran fine on 91-93 (pump gas) octane when I drove out from Cali. However, when I went to a local hotrod shop, the owner scared the hell out of me by telling me that I might have injured the engine because of the low octane fuel. So, now I am running a mixture of 110 and 91 octane to keep it safe for now. However, friends have told me that 91 octane is fine. Which is it.
BTW, these simple factors might have saved me: It was jetted to 70PPM jets, which was very rich, it was sucking some oil in through the PCV into the carb through the PCV hose, and the cam might have been steep enough to bleed off pressure fast enough to keep from damaging it. In any case, it is not damaged and I am grateful.
Old 03-14-2010, 03:53 PM
techinspector1's Avatar
Wiki Edits: 326
Iron-headed motors have been run on pump gas at 11.0:1 static compression ratios or even higher without detonating. You just have to run enough intake valve closing point on the cam to bleed off enough compression to prevent detonation. This is a balancing act, to close the intake early enough to trap enough mixture to make a good bang, but not so early that the motor detonates from the excessive cylinder pressure.
If you drove the car up from the coast where you had sea level air density without it detonating, I think the chances are pretty slim that it will detonate on the rarified air at altitude so long as you keep the air/fuel ratio handled properly.
Old 03-14-2010, 05:10 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
When I see "ppm" I think "parts per million" like when talking about pollutants in exhaust gas.
Jets are measured by the orifice size- this can coincide w/the diameter, like a 65 jet being 0.065", though there are small variations in the numbering systems used by the various manufacturers. So a "65" jet is just that, a 65 jet, not a 65ppm jet. Just so you know.
Adding oil through the PVC- or from anywhere if it's getting into the combustion chamber- can induce detonation. It shouldn't be considered a "safety" factor, but one to be avoided.
If you have Al heads, that will also help to offset some of the octane requirement as long as your cooling system is operating as it should. That, along w/the RPM being below the torque peak at cruise speed helps the engine to not have had a detonation problem.
Unless you have loud exhaust, you should be able to hear the ping of detonation and if that wasn't present- and your system quiet enough to have heard it if it was present- would be enough for me to relax.
It sounds like the speed shop counter help may be a 'flat lander'.
Old 03-14-2010, 07:04 PM
Wiki Edits: 326
Originally Posted by F-BIRD'88
over simplified internet theory
It's not internet theory. It's just a fact that you need to coordinate the static compression ratio with the intake closing point of the camshaft. Call up any cam grinder and ask for a recommendation. The first thing they want to know is the static compression ratio so they can match the opening and closing events to your motor so they can provide you with a cam that will operate at its max potential on the fuel you have available to you.
Old 03-14-2010, 08:14 PM
55effie's Avatar
Thanks for correcting me on the jetting issue. I am rather new to the technical side of hot rods. SInce I cannot get any info on the cam from the previous owner, I kinda have play it safe with the fuel I guess. I do have rather loud exhuast (dual 40 series flowmasters) and cannot hear the pinging, if it happened at all. There are no signs of engine damage yet, and I have corrected the PVC/oil issues already. Since I now have a 65 jet in the primaries, I think I will keep mixing the race fuel in to play it safe until I figure out some other options.
I want to eventually find out what my actual compression ratio is, since that race fuel is three times as much as pump gas. All I know how to check is the cranking pressure of the cylinder. How would I find the actual CR?
Also, I am gonna have to do some more research on the intake/cam timing issue. All that was a bit over my head at this point.
Old 03-14-2010, 08:49 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
If you didn't hot rod it all the way back you may have been able to get away with driving it home on 89 octane without too many issues. The only time the engine makes its max cylinder pressures is at WOT and the engine is at max load. At part/light throttle the cylinder pressures will be lower and you should be ok.
I had a 9.7:1 350 that I supercharged and had to mix 110 and 92 like you are doing. There were a few times I had to fill it up on 92 only and I just drove it lightly and never gave it a chance to build a lot of pressure and it was fine. I didn't do it all the time but there were a few times I didn't have much of a choice.
I'm also inclined to agree with Techinspector about your altitude saving you too. The air isn't as dense the higher you go which means your engine isn't bringing in as much and that will cause your cylinder pressures to drop as well. Of course, you will have a drop in power output as well.
Old 03-14-2010, 09:10 PM
Wiki Edits: 326
So, what is the cranking pressure?
Detonation can be seen on the plug insulators and will look like someone sprinkled pepper on them. The little black specks are molten aluminum from the piston crown that have been deposited on the porcelain.
Old 03-14-2010, 09:33 PM
55effie's Avatar
I have not actually measured the cranking pressure yet. I will get to it. I just got my Demon carb back on and fixed a few other little things this weekend. That 383 sure loves the race fuel.
Thanks, techinspector for the tip about the speckled spark plugs. Now I will know what to look for when I change the plugs next weekend.
Old 03-14-2010, 10:08 PM
ping
Someone (like a young engineer) has to be able to come up with a simple way to detect pinging on a non computor engine so the driver can crank back the timing with a m.s.d timimg control until suitable fuel can calm the savage beast.
ps I,ve got the timing control and it,s great if I could just hear the pinging ...
Clint
Old 03-14-2010, 10:38 PM
Wiki Edits: 326
Scroll down on this page to see aftermarket knock sensors all the way back to '61 models....
http://www.racepages.com/products/?N...+Sensor&N=1588
Old 03-15-2010, 07:23 AM
Banned
Yep, I was just going to say you can actually build your own knock sensor. If you're that worried about it I'd go that route. Get a cheap sending unit from a junkyard and find the directions to make the box on the internet. My buddy who's an EE did it in a weekend and granted he's an EE but he's still just an average over educated redneck like myself- it may take you two weekends but still isn't too bad.
Another thing to consider is cranking compression. Cranking compression and vacuum at idle (along with idle speed) can tell you a lot about how radical an engine is. Many "10.5:1" engines are more like 10:1 or even slightly less.
Old 03-16-2010, 06:29 AM
Banned
If you want to go fast for more than a few 1/4 mile blasts and like most of us pay our own bills, avoid the mindset of getting the last bit of engine cr reguardless of what others claim to do or claim theory will predict.
$ Its just not that simple $$$ After you have build a few that went over the edge, you figure that out.
VERY SOUND ADVICE!
Besides, what few people consider is that by going this route you lose low end tq, and on the street you will feel 15 ftlb at 2500RPM a lot sooner than you will feel 15hp at 6500 RPM. If you're running pump gas odds are you're planning to run on the street, which means you need to fit your powerband to street levels. I can't think of too many people that make every shift at 7,000 RPM when they go out on a Tuesday evening to get the groceries...
Old 03-16-2010, 06:59 AM
55,
the idle rpms needed and idle Hg readings and base timing will give you a solid first clue for how radical is the cam...
click on each chart on this link gives a typical expected Hg reading at what idle rpms for that much cam duration (at sea level):
http://www.compcams.com/Technical/DynoSheets/
a second check/clue is remove a valve cover and measure the actual lift on the intake and exhaust...
because:
to stay out of detonation range with high CR it is important that the ign base timing and centrifugal curve be matched to the cam and car combo....
here's a link to my favorite ign timing article:
http://www.gnetworks.com/v4files/bar...withimages.pdf
(anybody else having trouble with that link?)
my $.02:
the actual performance difference between 34* WOT and 36-38* WOT at the cam HP peak only shows up on a strip ET/MPH time slip,,,,you can't feel that last 10HP or so,,,until you sort out everything,,,, set it up with correct for the cam base timing and 34* WOT for some no detonation "insurance"....
(you can't hear high rpms/heavy load silent detonation)
PS: use the search function in the page header for "high altitude" tuning threads,,,the change in air density does change all readings (Hg/compression test/etc),,,,there are math correction "factors" to be applied against the altitude for everything including jets size....
"or"
LOL,,,use the search function to find a member named "Augusto" a sharp hot rod dude who lives and drives in the extreme high Andes altitude of Equador and PM him for help....
Old 03-18-2010, 09:53 PM
55effie's Avatar
Whoa, that was a bit more technical than I am used to. Thanks for the advice. Instead, I went online and found the old ad that the previous owner sent me of the truck and found that the CAM has 495 of lift. I assume that it's being measured in degrees. In any case, I have talked to a load of engine builders about this and they have all said pretty much the same things as everybody on this forum. So, Iwill stick to pump gas right now. It does not ping, and there are no other signs of engine detonation.
I dont drive it hard and have NEVER taken it above 4500 RPMs yet, and dont really intend to. I putt around and hit it hard on the freeway onramps mostly. Right now it is my daily driver, but that will change when I get my 4x4 back on the road. Colorado Springs is a bit scetchy this time of year with frequent afternoon snowfalls and 425 horsepwer trucks.
I did finally disconnect the PCV from the carb and let the two valve cover breathers do their job. I think that solved some other issues too. The throtle is more responsive and it idles lower too now. I do like the sound the engine makes at lower idle. There is something to be said about a v8 the lopes that hard because of the CAM. It just sounds tough.
Old 03-19-2010, 08:00 AM
LOL,,,what "you" like and what the motor "needs" to have a long happy life are not always in sync...
it's not rocket science...
a oem car purrs at low rpms idle because the piston intake stroke suction force and valves timing gives plenty of suction (about 18-20Hg) at the carb to correctly atomize the gas so it burns to make best power...
at idle a performance cam valves events leaks/looses to much piston suction force so the carb see's less vacuum Hg to be able to properly atomize the fuel so it can burn well in the chambers,,,so it "lopes"...
(which can cause liquid gas to wash the oil off the rings and cylinder walls and foul the plugs and contaminate the oil in the pan)
depending on the cam,,,idle may well need to be as high as 1200rpms to make enough suction Hg to atomize the gas (click on those comp charts for details)
it's a no brainer to plug a vacuum gauge ($40?) into the carb manifold vacuum port nipple with a piece of hose to see what the suction force is at idle and adjust the rpms on the linkage....
ask around for what Hg is needed at your altitude to atomize the mix,,,at sea level a carb likes to see 12Hg plus for great atomization at idle...
there is soooo much a simple vacuum gauge can/will tell ya...
scroll down on this link and click on the examples for just some of the diagnostic uses:
http://www.secondchancegarage.com/public/186.cfm
even very smart to mount it on the dash to serve as a "check engine" warning (values change from normal while driving or needle shakes)....
also helps improve mpg by being a watch dog for you right foot,,,high Hg=lean,,,and many have markings like the attached,,,green=economy...
Name:	vac gauge.jpg
Fuel mileage, compression ratio, and octane? BlackAndChrome Engine 3 03-14-2010 05:22 PM
compression ratio, aluminum heads, forced induction, Gladis Engine 3 02-27-2008 08:10 AM
Octane Booster Info SLR_65 Engine 46 09-30-2007 09:01 AM
Compression Ratio ron eckman Engine 4 01-13-2004 06:43 PM
High compression ratio pistons invincible Engine 6 09-22-2003 10:16 PM
