Compression ratio math - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2011, 06:23 PM
spinn's Avatar
283 v8 build with vortecs-
stroke is 3"
chamber 64cc, but the stock 283 head was 64 cc.
gasket bore 4.000" .027 thick, 5.56cc
pistons .025 under deck 4 cc with 7cc relief, 11cc total
That is 8.15:1 . It might be a lil thin , but 70s compression numbers were in the 7.5-8 range.
305 Vortec swap-
Stroke 3.75"
chamber 62cc, milled .025"
gasket 4.000" .027" thick, 5.56cc total
pistons .020 under with 7cc relief, underdeck total 10.77
That comes to 9.0:1 compression. Good for a heavy truck and regular fuel.
Old 02-19-2011, 08:24 AM
spinn's Avatar
The bore and stroke should be clearer.
283 bore 3.87" stroke 3.00
305 bore 3.75" stroke 3.48
Is the math correct?
Old 09-29-2011, 09:28 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If I understand you correctly, this is a 0.020" over bored 283 (3.895" bore), 3" stroke, 0.025" piston below deck, 7cc valve reliefs, 62cc chambers, 0.027" gasket thickness x 4" gasket bore diameter.
In inches
Enter Bore size: 3.895
Enter Stroke size: 3.00
Enter Head Gasket Bore size: 4.00
Enter Compressed Head Gasket Thickness: 0.027
Enter Combustion Chamber Volume in CC's: 62
Enter Piston Dome Volume in CC's use "-" for Dished Pistons: -7
Enter Piston Deck Clearance If ABOVE deck use "-" : 0.025
Compression Ratio: 8.37:1
Total Volume: 79.44 cc
With a standard bore the CR is 8.30:1
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
compression ratio zoomo Engine 11 08-27-2010 01:37 AM
Compression Ratio Help KillerK10 Engine 3 02-10-2010 05:02 PM
compression ratio to psi jgh64pkup Hotrodding Basics 1 12-09-2008 06:03 PM
396 compression ratio crazyman Engine 4 01-30-2004 06:05 PM
