Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression ratio vs. pounds per square inch.
Old 03-15-2013, 07:53 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Also, it doesn't matter if you're talking a 6-71 or 10-71 blower, you need to be looking at boost pressure, that's what will increase your static c.r. to higher effective c.r. Meaning an 9.0:1 static c.r., with 10 pounds of boost will net you an effective c.r. of 15.1:1.
Semper Fi
