Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression ratio vs. pounds per square inch.
Old 03-16-2013, 11:03 AM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
Originally Posted by MouseFink View Post
When considering CR to boost pressure, the limit for 93 octane pump gas is 12:1 effective CR. Anything over 12:1 effective CR will risk catastrophic detonation.
Static CR.................8:1
Boost pressure ....... 8 PSI
Effective CR.............12:1
Experience has shown that an engine will make more power from low CR - high boost than from a high CR - low boost. Engines will differ in their tolerance to detonation so this rule is not hard and fast but it is a good place to start. It is easier to change boost than it is to change compression ratio.
Yep, what he said ^^
Semper Fi
