compression ratios - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 04:01 PM
swompz's Avatar
compression ratios
can anyone tell me If I would notice any difference / what hp gains I can expect to see stepping up the compression ratio on my mild 350 chevy from 8.8.1 to 9.6.1CR ?
cheers
Old 04-22-2012, 05:56 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
cheers
If this is to be run on pump fuel you would be wise to compute the dynamic compression ratio using the new CR to be sure the octane requirements aren't excessive.
Old 04-22-2012, 06:01 PM
swompz's Avatar
I was going to use rhs pro torker 67cc heads 12402,s so stock/ mild performance which would give me the 9.6.1 , but ive been offered a set of stock 76cc heads for. Third of the money, so weighing up best bang per buck option, still trying to keep in 300hp zone on. 350+40 bore with performer manifold & cam/ headers etc.
Old 04-23-2012, 01:28 AM
swompz's Avatar
It's a case of whats available to me hear in UK at sensible money, Which is slim pickings compared to you guys.
Mostly it's stock later model heads or a thin selection of performance heads
Catalytic converters and compression ratios Nuck Chorris Engine 6 09-05-2011 12:19 PM
283 Compression Ratios Bull_81073 Engine 15 02-21-2008 07:13 AM
benefits of high compression ratios mista-nova Engine 11 02-23-2007 11:20 AM
compression ratios camaroking383 Hotrodding Basics 4 05-27-2006 04:26 AM
cams, heads, and compression ratios Litdave Engine 3 05-22-2004 08:47 AM
