This might explain it
You can try to run a small lift cam, in a higher compression engine, but you will need to run a real rich mixture of high octane fuel, and tune it perfectly. Larger lift cams, will allow you to cut down on the fuel mixture some, but you still need the higher octane fuels. Here is a link, that answers your question, I hope. http://www.faqs.org/faqs/autos/gasol...section-1.html Stephen PS: I like to tune them lean and mean, but have no detonation at wide open throttle. Build yours up to a maximum of 10.3 CCR, so you can still run pump fuel. It can be tuned to perform this way. Last edited by carsavvycook; 11-11-2008 at 08:15 PM. Reason: spelling |
The OP's question is regarding compression........and pump fuel, and how high can you go. You have 'twisted' some very good information, given by very knowledgeable members, on this thread. You make it sound like YOU wrote the Book on engine performance. I think NOT. Last edited by carsavvycook; 11-12-2008 at 09:41 AM. Reason: addition |
I did no write the book, I could write a book, but books are only good once so I stay away from it. As far as 383 and aftermarket parts. We could talk about running some of the trick heads out there, equally trick valve train, with a rerouted cooling system and top of the line fuel and ignition control to allow for compression that can go past 12:1 on pump gas. Or you can run 11:1 on well massaged Vortec's with a carb and HEI... We're talking about what is possible, not what is common. |
This is from your profile: Biography: mechanic, attending SEMo for Construction Management, own a S10, a Blazer, a Cutlass, and a POS wish it would die Escort Location: St. Louis, MO Interests: cheerleading lifting Occupation: mechanic, part time laborer 23 years old - most good BS Engineering degrees require 5 years. Where did you get your BS and in what discipline? You claim Civil. I am a retired Civil, registered land surveyor. BS University of Pittsburgh. Do you really have a BS degree in any Engineering discipline?? How can you call yourself an engineer without a BS? I asked you this question before, and received no answer. |
It is knowledge only verified with hands on experience. This takes years to acquire. This is not found on a computer program, or on the 'net'. By the way, 12:1 will not run on pump gas. I know from trial, and error. Trial + Error= Experience. |
That profile hasn't been updated in a LONG time. I guess I didn't think people actaully read it. And yes I'm 23, that part is current. I no longer cheerlead, may try to get on as an assistant coach though. And I'm curently a project engineer in the St. Louis area. I'm also a Leo and I enjoy holding hands and long walks along the river.
I wish I could find the article, but I swore I saw a dyno challenge with ratios runnig a little over 13:1 on 93 octane. Of course these things were tuned perfectly, were dyno queens, and had exceptional cooling along with coatings. To prove it can run in an engine look at motorcycles, a lot of them are running on pump gas at that ratio or higher- again its a different engine but it shows that it is possible to do with that octane. I'm not saying I can build an engine to run 12:1, or rather would even try to (too cost prohibitive), but some people can get 10:1 to run on pump gas- doesn't mean someone else can't either. For a long time man couldn't see beyond the stars in the night sky, then we sent up the Hubble, only to realize there's more that we can't see. |
This reads to me(you quoted me) THAT I NEED TO LOOK OUTSIDE OF THE BOX(not yelling). Just trying to prove a point. I have been blessed with mechanical abilities, by our all mighty God. I only have a high school diploma, and have been able to succeed in the automotive, and performance industry. The school of hard knocks is the best learning experience you can have. Check my previous posts, and try to be less abrasive, and more open to the knowledge base available on this site. If you want a summary of what I have accomplished, PM me. Stephen |
There was a time, back in the day of flat head fords, that if you said 9:1 you were out of your mind. Yet that's below factory now-a-days. And not to discredit expierence, because it is the reason we are where we are today, but expierence in itself is nothing if you do not analyze it properly and find the best way to apply it (I know a lot of well expierenced people who don't have much of anything to show for it). I'm grateful for the learning of the men who walked this earth before me, but I'm also grateful for the people who challenged it. |
Not until after WWII did high octane leaded gas become available at the pump, allowing a higher compression ratio. 50 60 and early 70's mom and pop cars had higher compression ratio then we can run now. (cause you could buy the gas for them. Many many racers modified their flat head motors to run on Methanol or ethanol with a very high compression ratio 12:1-13:1 + Do some research using the terms Ricardo and high compression and detonation and catch up with the rest of humanity. All your fancy "modern" combustion chamber shapes and "out of the box" theories you see today were researched by Ricardo and others before WWII. A lot of thinking out of the box done back then to develop high performance fighter engines and "modern" high octane racing fuels. Piston engines research took a back seat to the new "jet era" after WWII but the availabilty of cheap high octane gasoline allowed the "high compression" modern motor of today to be in every garage in the 50's and 60's. Electric cars were perfected and readily avaliable before gasoline was readily avaiable. Nothing much has changed on an internal combustion motor in 100 years. But we'll let you go on it cause you are young and inexperienced. |
Once again you post a twisted post. "but expierence in itself is nothing if you do not analyze it properly and find the best way to apply it" What in the h**l do you think everyone in your lifetime is expected to do? Match your success? Everyone has a mind of their own, and winds up happy in their 'nitch' of their life. Not everyone is perfect. This is what life is all about. |
I'm only saying that expierence is in itself meaningless, If I put my hand in a fire and get burned I have expierenced burning and pain. If I do not analyze what has happened and deduce that fire will hurt me if not treated properly then I have learned nothing. Likewise if I assume that all fire is bad and painful then I have "learned" something, but I will never realize the bennifits of its heat and light because I have learned to not go near it at all. No one can argue that point. Many people who have done things before us have shown us some of the possibilities, but no one has yet discovered all of the limitations, and even when these "limits" are set it is only a matter of time before someone else finds a way to push through them. Just like when Columbus rediscovered America. I am not trying to say that I am going to rediscover America either. Merely that none of these so called constants should not be taken for granted, all of them have changed in the past and will change in the future. And to F'bird, I know the gas back in the day was crap, refining has made some improvements since then. Likewise even when there was leaded gasoline I would not run those engines run on today's gas unless I wanted the valves to chew up the heads. I would also not run todays engines on that leaded gas because the fuel and exhaust system can't take it. Not only has the technology in engine design and manufacturing changed, but so have the parameters. Nothing is constant, nothing is set in stone. Lastly cook, I'm not trying to discount what you say or what you know, but knowledge does expire. What you know is worth the most when you learn it, and as time goes by and the world changes so does the value of your knowledge. There was a time when simple potassium nitrate was the best chemical to have in warfare, and then came trinitrotoluene, then the A-bomb, then the H-bomb, and now... well only God knows all of what they have. Each invention served its purpose in shaping the world, each inventor was just as crucial, and each one's importance began diminishing as soon as their product came into use. |
| Octane Booster Info | SLR_65 | Engine | 46 | 09-30-2007 09:01 AM |
| Need help on my engine. | evil.350@hotmail.com | Hotrodders' Lounge | 4 | 08-18-2007 07:06 PM |
| Compression question for the Pro engine builders.. | Axelrod | Engine | 14 | 01-16-2007 10:29 AM |
| cams, heads, and compression ratios | Litdave | Engine | 3 | 05-22-2004 07:47 AM |
| Compression | 4x4vandale | Engine | 5 | 10-08-2003 11:59 PM |
