Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression for street 383 question??
Old 02-04-2013, 11:56 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Wiki Edits: 9
Keep in mind there are no "9.5" pistons", any piston that results in a 9.5:1 c.r. is a piston with a particular top design, dished, domed, flat, and the sum of other parts, bore, combustion chamber volume, deck height, head gasket thickness, etc. So consider all factors in the equation before you fall victim to what some manufacturer or seller might call a xx.x:1 c.r. piston.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
