Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compression on street tunnel ram
Old 11-23-2007, 07:37 AM
woodz428's Avatar
woodz428 woodz428 is offline
Troll Hunter
Originally Posted by 383
On the street ram ,if a cam gets used that makes peak power above 7000rpm,
would it still make good power there? Edelbrock said its for under 7500rpm motors.
I would like to make 1.4-1.5hp per cubic inch.(383)
Can it be done with this setup? I need to choose the rotating assemblies compression and cam.
It appears to me you are building an engine from the manifold down. That is kind of backwards to the way that I think it should be done. Depending on those components that you have yet to choose, it shouldn't be hard to get the 1.5hp per cube....with just a 4 barrel.
