Compression stroke vs. Exhaust stroke - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-23-2007, 01:14 PM
i have my 351 #1 piston at TDC. the dots on my timing chain are at 6 and 12.
what is the difference between compression stroker vs. exhaust stroke? both valve appear to be closed...
im trying to figure out how to put in a distributor? will it be "180 out" whatever that means...???
Id appreciate any help
Old 03-23-2007, 01:27 PM
Last journal entry: car is painted
Compression stroke happens after the intake valve closes. Exhaust stroke happens with the exhaust valve open. Just think about how an engine works and watch both the valves and the piston.
Old 03-23-2007, 01:34 PM
Compression stroke
If both valves are closed you are on the compression stroke. When the opposite cylinder in the firing order has both rocker arms rocking your target cylinder is on compression and both valves shut. Ignition occurs during the compression stroke so if you align the distributor to that cylinder you will have the timing close to correct.
Old 03-23-2007, 01:43 PM
thanks so much
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 10:29 AM
Big bore vs. Long stroke Blazin72 Engine 32 12-03-2006 04:12 PM
Compression concerns. Siggy_Freud Engine 4 07-11-2006 10:06 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 12:48 PM
