compression test - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2014, 03:29 AM
bjautos7's Avatar
compression test
hi , I did a compression test on a 350 chevy , here is what I got (1)180 (3)175 (5)180 (7)175 psi other side (2)170 (4)165 (6)165 (8)162. engine runs and sounds uneven and is very rich as spark plugs are black . there no water in the oil but can see water drops up top of the valve covers. is this a blown head gasket or something more.
Old 05-10-2014, 06:52 AM
LATECH's Avatar
Engine is OK. compression reading is acceptable. Should run fine. Rebuild the carb, as it is obviously running rich, fouling plugs and making it run rough.
Water is a normal by product of combustion. A warmed up motor will dry the moisture out through the PCV system after it runs a while. Nothing to be alarmed about.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
Denny (05-10-2014)
Old 05-10-2014, 11:13 AM
ericnova72's Avatar
More for Less Racer
x2 ^^^^^ what he said. Could have ignition issues also, but those compression readings are fine.
The Following User Says Thank You to ericnova72 For This Useful Post:
Denny (05-10-2014)
compression test and leakdown test? crussell85 Engine 7 07-26-2013 03:58 PM
compression test sadie00 Engine 4 12-27-2010 09:04 AM
compression test help legionlleh Engine 2 03-24-2007 10:07 PM
Compression Test stratt134 Engine 3 07-26-2006 02:58 PM
Compression test blockhead Engine 2 11-30-2002 12:22 PM
