Compression Test
A buddy of mine was doing a compression test on a 350 Chevrolet engine and was getting between 150-180psi but on a couple of cylinders was getting nothing,
Why is this? His car was running fine except he was losing power in 3rd gear (Automatic 400 tranny). Now his car won't start Why is this? |
cheap tools? motor in desperate need of work?
Mac Compression Gauge
Engine was running good but loosing power in the top end. 1st and 2nd gear lots of power but in drive it was sluggish |
Test
Are the dead cylinders side by side???? Any more info on the engine??? Race only??? compression??? Does he spray it???? Keith |
The rockers are ok.
We did a compression test on 5 of the 8 cylinders (headers in the way) 2 of the dead cylinders were side by side The engine is a 350 is a 350 with 12:1 compression, low tension rings. Hasn't used the juice in a long time. Street engine. Engine will not start when we atempt to turn it over. There is a good spark and fuel PLEASE HELP |
gasket
If the zero cylinders were side by side i say it has a torched head gasket/burnt block.... No need to even try to get it running. It needs to come out....
Keith |
Would this cause it not to start?
compression test
Try running the compression test by squirting a little oil into the cylinders through the spark plug hole, and hold the throttle wide open when cranking the engine. It should not require more than 4-5 revolutions of the engine to get a good compression reading on each cylinder. See if you come up with some better readings. You should not have a variation of more than 10 psi between all the cylinders. If this is the case, and no compression in a couple holes, it sounds like time to yank some heads and see whats inside.
PS, be sure to have your ignition system completely disarmed before turning over the engine. |
Side by side.....sounds like a blown head gasket to me.....It should still start, but would have a definite miss.
Ontario Rodders |
make sure the tool is in good working order check all the holes and record the info if still nada then pull the valve covers off make sure everything is moving right if still nadadammthing then brace yourself your going in!!
if you pull all the plugs it will spin easier if you have to drop the headers then do it to get the readings (man i hate headers) is there ant cross contamination??water in oil... oil in water compression in the oil or water??? sr66
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Thanks every one
| Compression Test Results....Rings or Valves ? | white66coupe | Engine | 10 | 10-14-2004 07:58 AM |
| Need help with compression test data | Slickriffs | Engine | 16 | 07-19-2004 02:24 AM |
| 350 compression test results rebuild or leave it alone? | Buffed | Engine | 3 | 01-05-2004 03:55 PM |
| Compression test results... | tom_scott | Engine | 6 | 01-04-2004 03:54 PM |
| Pontiac Compression Test | smily1 | Engine | 7 | 11-12-2003 12:26 AM |
