Compression Test - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2006, 01:15 PM
Compression Test
Just did a compression test on my 383 stroker, vortec heads. About 500 miles on the motor, I'm not sure if the rings were done correctly....
165psi, after about 5 minutes it was down to about 160psi
How does that look? This is my first compression test.
Also, motor was cold, haven't started it in a few days. I didn't know if I was supposed to do the test with the motor warmed up or not.
Thanks,
Sean
Old 07-26-2006, 01:43 PM
Last journal entry: PICTURE TEST
test
With out knowing more about your engine it's tought to say if that is a good number...
Go back and do all 8 cylinders, with a warm engine and the carb opened...
let us know the results... Don't forget to disable the ignition......
Keith
Old 07-26-2006, 01:53 PM
35WINDOW's Avatar
Last journal entry: Engine!
With regard to Ring Sealing, would it make sense to do a "dry" test as well as a "wet' test?
Old 07-26-2006, 01:58 PM
What else would you like to know about the engine?
I will re-try with a warm engine in a few days, I can't do it quite yet.
Thanks,
Sean
How to figure compression ratio...... classic_chevy_guy Engine 9 07-26-2005 09:59 PM
Compression Test Results....Rings or Valves ? white66coupe Engine 10 10-14-2004 07:58 AM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 09:34 PM
350 Chev Engine compression test Seon Engine 4 12-14-2002 08:20 PM
Compression test blockhead Engine 2 11-30-2002 11:22 AM
