Compression test on engine cradle - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2012, 03:07 PM
I need to do a compression test on my engine cradle stand, i need to wire up my starter, i have one of those remote hand held starters,
"2" on my starters goes to (+) on my battery
where do i hook up the 2 leads (Red/Black) and (Black) from my remote starter to on the starter?
and where do i hook up my (-) from the battery too?
Thanks
Old 07-05-2012, 03:53 PM
ericnova72's Avatar
More for Less Racer
Red/black wire from your starter switch to the battery (+) post, black wire from switch to #3 post on starter.
Battery (-) post connect to engine block.
Old 07-05-2012, 04:02 PM
Will the engine try and flip over when doing a compression test on a cradle?
Old 07-05-2012, 04:12 PM
ericnova72's Avatar
More for Less Racer
Nope, because the engine isn't connected to anything on the flywheel end. It isn't trying to rotate against anything.
The Following User Says Thank You to ericnova72 For This Useful Post:
2wld4u (07-05-2012)
Old 07-05-2012, 04:20 PM
Do i need to hook up a battery cable from + battery to #2?
Old 07-05-2012, 04:42 PM
Richiehd's Avatar
JS-70
Yes, battery + to#2
ericnova72's Avatar
More for Less Racer
Yes you do
Old 07-05-2012, 06:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The engine will jump pretty good at the hit of the starter.
engine cradle positon on a model a pick up swanson1930 General Rodding Tech 25 03-31-2012 04:28 AM
Anybody used an engine cradle? 0pyders Garage - Tools 13 02-14-2011 10:53 AM
Engine cradle SPIIRIT Engine 4 05-19-2004 10:42 PM
Engine cradle testing stand Longboard Garage - Tools 3 04-20-2004 01:39 PM
350 Chev Engine compression test Seon Engine 4 12-14-2002 08:20 PM
