Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compression test numbers on 350
Old 03-05-2013, 11:26 PM
PatM PatM is offline
You might want to look for a cause of that overheating. Perhaps some sort of debris in yhe passenger side head? I don't know enough about the cooling system to "guess" what might be happening. But if you have it torn down, and it overheats again, you might blow out another gasket. You might want to investigate around a bit while it's opened up.
Pat
