compression test results - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2010, 03:40 PM
does this in any way determine how much compression my engine has? I got 230-250 psi across the board.
Old 06-01-2010, 03:52 PM
That's high. Usually I'll end up with something between 150-175 psi. And sometimes I'm over-cammed. But over-200 psi is high.
What are the specs on this engine?
Old 06-01-2010, 03:55 PM
it's not the gauge. I think what I've been chasing as timing/tuning is way too much compression from this motor. It came out of some circle track race car.. Now the question is what is the cheapest way to lower it??
Old 06-01-2010, 03:57 PM
Big chamber smog heads. They're cheap (pretty much FREE), and will drop your numbers.
That's if "cheap" is your primary concern. You'll lose performance though...
Old 06-01-2010, 03:59 PM
my performance can't be any worse than it is now.
Help - low compression #3 cylinder on sbc olympic73 Engine 3 05-03-2010 07:16 PM
Q-jet throttle stuck open, backfired, and now won't idle Cousin_Joe Engine 24 09-15-2008 05:34 AM
Proper way to do a Compression Test Riot Racing Engine 11 02-15-2006 01:47 PM
cold compression test tommyhawk13 Engine 2 01-15-2006 10:45 AM
Fiero Compression test....what should the #'s be? Rubberman2003 Engine 6 02-02-2004 12:17 PM
