compression test results - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2010, 04:08 PM
F 40-0-60-65
R
O
N
T 75-40-59-35
This is from an all original 1968 327 4bbl. tons of blowby out oil filler tube and valve covers, has been sitting since 1977. Ouch, rebuild time.
Old 09-04-2010, 04:26 PM
Dirty Biker's Avatar
Bold As Love
yikes! maybe the crankcase ventilator on the back the motor is plugged too? i guess a zero in one of tthe cylinders could mean a bent or bad valve tho, that aint good... be a cool motor tho when you rebuild it!
Old 09-04-2010, 04:53 PM
bigdog7373's Avatar
Of course it's fast
Definitely needs to be rebuilt. I don't see any numbers there that i would be pleased with.
Old 09-04-2010, 05:28 PM
sqzbox's Avatar
My pipes are my music
How did you do a comp. test on it after sitting 34 yrs? After that long, a rebuild is sort of a gimmie even without testing it.
Help with Compression Test on 305 kahl_454 Engine 15 01-12-2010 03:59 PM
Q-jet throttle stuck open, backfired, and now won't idle Cousin_Joe Engine 24 09-15-2008 05:34 AM
Proper way to do a Compression Test Riot Racing Engine 11 02-15-2006 01:47 PM
Compression Test Canadian Charlie Engine 11 06-01-2005 09:39 PM
Pontiac Compression Test smily1 Engine 7 11-12-2003 12:26 AM
