compression tester - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2009, 05:12 PM
compression tester
I need a new screw in compression tester, What is a decent one for decent money.Thanks for your imput.
Old 09-04-2009, 05:34 PM
302 Z28's Avatar
For one that you are relying on to make a living with the Harbor Freight one will serve the home hobbyist well.
Vince
Does a tunnel ram raise or lower Compression?? d&c repairs it all Hotrodding Basics 61 02-02-2009 07:00 PM
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 11:29 AM
400 small block compression and head gasket question 19nova72 Engine 2 07-07-2005 10:49 PM
Cranking Compression 10.5:1 lluciano77 Engine 7 09-30-2003 01:27 AM
High compression ratio pistons invincible Engine 6 09-22-2003 11:16 PM
