compression testing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2007, 01:23 PM
compression testing
Can you do a compression test without using the starter to crank the engine? Could I just use a big breaker bar on the balancer bolt? How many rotations are necessary to get an accurate average-----2, 4, 6?
Old 07-22-2007, 08:41 PM
You can't spin it fast enough that way! Use the starter and have carb wide open, just disable ignition.
Old 07-22-2007, 09:12 PM
383silverado's Avatar
is it on an engine stand ?
if so just bolt up the starter and use a battery with some jumper cables to crank it.
Compression question for the Pro engine builders.. Axelrod Engine 14 01-16-2007 11:29 AM
Compression concerns. Siggy_Freud Engine 4 07-11-2006 11:06 AM
Compression Testing ....(Hot vs Cold)? white66coupe Engine 3 06-30-2006 01:01 PM
Compression testing question. schnitz Engine 28 11-06-2005 04:30 AM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 01:48 PM
