Compression Testing: EFI Engine (Removed from Vehicle) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2012, 11:59 AM
lt1silverhawk's Avatar
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
Hi All,
I need to do a compression test on an LT1 engine that has been removed from the vehicle. Can it still be done following the same steps as for an engine that is still in a car?
Presently, the engine is on a stand with all the accessories and harness still attached.
Thanks in advance!
Old 05-19-2012, 08:30 AM
S10xGN's Avatar
Gotta love a turbo!
Sure, you're only concerned with cranking it over. Pull the plugs, block the throttle blades open, wire a good battery hot+ to the starter and ground- to the block. Use a screwdriver between the starter+ and solenoid to crank it.
Russ
Old 05-19-2012, 08:40 AM
Wiki Edits: 132
That's what I figured, but just wanted to make sure as I've never done it before. Thank you!
compression test, efi
Torque converter testing, off-vehicle mannasugar Transmission - Rearend 2 05-11-2009 01:53 PM
compression testing Gladis Hotrodding Basics 3 02-27-2008 08:06 PM
compression testing sam83k10 Engine 2 07-22-2007 08:12 PM
Compression Testing ....(Hot vs Cold)? white66coupe Engine 3 06-30-2006 12:01 PM
Compression testing question. schnitz Engine 28 11-06-2005 03:30 AM
