Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compression Testing ....(Hot vs Cold)?
Old 06-29-2006, 05:04 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
The generally agreed upon standard is 10%. You can run another test cold by squirting a small quantity of oil in the cylinder, turn the engine over a few times and recheck the compression. If there is 10% differance then the rings are worn.
You say the engine was rebuilt. Was it bored and new pistons installed, or just a ring job?
Vince
