Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compression testing question.
Old 11-03-2005, 05:51 PM
mike 96 ws6's Avatar
mike 96 ws6 mike 96 ws6 is offline
old dog learning new tricks
Oh. Sorry. To answer your question, with a healthy motor, you will get the same result either way, regardless of cranking RPM affected by whether the other 7 cyl.'s have plugs or not. There's a physical formula to get the CR with a healthy motor.
With a motor leaking compression, it may need to turn over an extra time or 2 to reach it's max with the plugs in those other 7.
