Compression Values For Engine That Refuses To Run - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 03-17-2012, 02:43 PM
malc's Avatar
Living At The Speed Of Life
Pistons are 0.020 down the bore and I did use the 0.051 gaskets,
I would have liked thinner but Iīm using what I have at hand.
Quench = 0.071.
  #47 (permalink)
Old 03-17-2012, 03:36 PM
thinwhiteduke's Avatar
Living In The Past
Hmmm.... effective high side is about .0060"
Gaskets aren't THAT expensive. I'm having to wait almost 4 weeks to get some .0030" Cometics from summit just to keep my quench where I want it at about .0038" - .0040"
I think it's important, but that's just me.
Duke
  #48 (permalink)
Old 03-17-2012, 03:40 PM
techinspector1's Avatar
Wiki Edits: 326
Quench = 0.071.
Are you serious? You're compromising a build for the price of a set of head gaskets?
  #49 (permalink)
Old 03-17-2012, 03:46 PM
Wiki Edits: 326
Duke
Duke, I understand what you're trying to say, but you need to bone up on your math a little.
.0060" is six thousandths, not sixty thousandths. 0.060" is what you meant.
.0030" is three thousandths, not thirty thousandths. 0.030" is what you meant.
.0038" is three and eight tenths, not thirty eight thousandths. 0.038" is what you meant.
.0040" is four thousandths, not forty thousandths. 0.040" is what you meant.
  #50 (permalink)
Old 03-17-2012, 04:10 PM
Living In The Past
Oh thanks tech..I'm usually pretty good on math, but I sure screwed up by a long shot there!... Lucky I don't work in a bank! I think (hope) the OP knows where I'm coming from...
Thanks for the correction!!
Duke
  #51 (permalink)
Old 03-17-2012, 05:08 PM
malc's Avatar
With the oil problem and now this my car has been unuseable for a year now.
Looking for the "vacuum leak" has cost me four sets of intake gaskets and weeks of waiting.
I do have some 0.015 Fel Pro 1094s but they are labeld as needing an
extra smooth finish.
I couldīnt find the 0.015 Victor Reinz gaskets I had before and the next thinnest Fel Pro option is 0.039.
Another option would be an SCE 0.021 gasket weighing in at $92.66 a pair,
then I have to add shipping halfway around the world and duty.
Edit:
So the 0.039 Fel Pros would squeek me into the ball park @ 0.059 Quench.
A couple of those will cost me $150.95.
  #52 (permalink)
Old 03-17-2012, 10:23 PM
Living In The Past
I paid US$180 for mine , FULL way round da world...
Cheap dollars IMO for correct quench... Especially considering the heartache your going through with this saga!...
Duke
  #53 (permalink)
Old 03-17-2012, 10:26 PM
Living In The Past
Tech, BTW, "bone up" I like that!!!
  #54 (permalink)
Old 03-18-2012, 05:37 AM
malc's Avatar
I always thought "bone up" was an English expression and Americans used "cram".
Anyhows Iīve ordered up the Fel Pros 0.039 gaskets plus another set of intake gaskets.
  #55 (permalink)
Old 03-19-2012, 04:37 AM
Living In The Past
Well down her in Aus "bone-up" lends itself to more of a phrase of "being a man"
But anyways I would have ordered twenty thou gaskets......Good luck!!!
  #56 (permalink)
Old 03-19-2012, 06:04 AM
malc's Avatar
I just got on the phone to Summit and the gasket
to suit my application is Clevite 0.026, so thatīs what Iīm getting now.
  #57 (permalink)
Old 03-19-2012, 01:18 PM
Living In The Past
That's good mate. I'm glad your not using the .051" gaskets with a piston that's .020" down from the deck.. I hope you've ironed out your vacuum issue in the process..
Duke
  #58 (permalink)
Old 03-19-2012, 01:29 PM
malc's Avatar
thinwhiteduke, check your PMs.
  #59 (permalink)
Old 03-19-2012, 01:57 PM
engineczar's Avatar
Malc before you put your heads back for the last time here is something I do to confirm whether or not the intake will sit properly on the block.
With the heads just snugged down (not torqued) onto the block with the head gaskets.
Place the intake on the engine with no intake gaskets. The intake should nearly sit on all 4 surfaces. The two intake surfaces and the front and rear rails of the block.
If the intake faces of the heads need cutting then the intake will sit high and you'll have a pretty good sized gap between the bottom rails of the intake and the front and rear rails on the block. More than a .06 gap and I'd think about doing some cutting. This is sometimes the case if the decks of the block have been cut.
If the intake sits on the block and there's a gap between the intake and the intake faces of the heads then the front and rear rails of the intake may have to be cut to drop the intake.
Doing it prior to torquing down the heads will save you a set of head gaskets should you need to make any mods.
BSE Racing Engines
  #60 (permalink)
Old 03-22-2012, 06:25 AM
refuses to run
Hello, Im new here but have read threw your entire issue, just wondering if you have turned the engine over and made sure all your cam lobes are good?
Saginaw refuses to shift when hot Saito Transmission - Rearend 9 01-04-2011 07:06 PM
My wife refuses to support Bailouts!! Javelin360 Hotrodders' Lounge 14 06-21-2009 09:31 AM
Adjust Values Wayne Wagstaff Hotrodding Basics 4 05-14-2007 11:08 AM
392 Hemi Values FM2000 Engine 1 06-16-2004 12:25 PM
