Compression Values For Engine That Refuses To Run - Page 7 - Hot Rod Forum : Hotrodders Bulletin Board
  #91 (permalink)
Old 04-18-2012, 12:26 PM
malc's Avatar
Living At The Speed Of Life
I´ve not seen a pawn shop in Spain.
Nevertheless, what I´m getting is cheapish, good enough though to see what I need to know.
I was going to get a Summit dial but can´t wait the week for it to arrive.
  #92 (permalink)
Old 04-18-2012, 12:46 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I saw in your earlier posts you were from spain!! Are there any places you can rent an indicator? And by the looks of your lifters I dont see any bowled bottoms which indicate wear on the cam!! And ive seen cam lobes wore terribly bad and engines still idle!! But I have seen the fuel pump actuating rod wear down and the fuel pump not get a full stroke!! you may want to pull your pump and check the length of the actuating rod thats located behind the fuel pump plate and rides on the cam it may have excessive wear?
Chris
  #93 (permalink)
Old 04-18-2012, 01:52 PM
Or, if your pump is of the servicable variety, open it up and check the diaphragm and the valves. A stuck valve, a bad diaphragm. Either could be part of the problem.
Pat
  #94 (permalink)
Old 04-18-2012, 01:58 PM
malc's Avatar
Chris
I just put a straight edge to several of those lifters at random,
held them up to the light and all have dished bottoms.
  #95 (permalink)
Old 04-18-2012, 02:00 PM
malc's Avatar
Pat
I´ve tried two pumps on it already, one Edelbrock and one Holley.
  #96 (permalink)
Old 04-18-2012, 02:57 PM
thinwhiteduke's Avatar
Living In The Past
Still sounds like a vacuum leak to me.
Duke
  #97 (permalink)
Old 04-18-2012, 06:38 PM
refuses to run
They guy talking the fuel pump rod wear is correct, the guy asking about oil return hole is also correct. Im my opinion I would do as another guy said and bolt on a electric pump before your pressure regulator and it will probably start. also im concerned about your broken oil filter housing adapter. why was it broke and is new one install correct. do u have the adapter lined up correct? steve
  #98 (permalink)
Old 04-19-2012, 04:36 AM
malc's Avatar
I´ll check the pump pushrod next and the lift at the rockers.
The oil return hole is there, no problem there since I built the motor.
I think this broke due to age and maybe me overtightening the oil filter
a few times.
The new adapter is installed right.
  #99 (permalink)
Old 04-19-2012, 01:21 PM
Dished Lifters?
Hey Malc.
Seems like you're pretty astute. This is probably just semantics. Just to make sure we all understand, when you say the lifters are "Dished", that sounds to me like they have a concave face. If the face is (rounded) convex, good. If it is dished (concave) . . not so much. I trust you mean that the lifter faces have a spherical crown, and are convex in form.
PatM
  #100 (permalink)
Old 04-19-2012, 03:05 PM
malc's Avatar
Hey Malc.
PatM
The lifters are concave, I put a straight edge on them and held them up to the garage light, definately concave.
Just got me reasonable pic of a lifter.
  #101 (permalink)
Old 04-19-2012, 03:16 PM
malc's Avatar
Here´s a macro shot of the base, the marked inner ring is concave.
This shot viewed large inmy gallery shows the surface pitting.
  #102 (permalink)
Old 04-19-2012, 03:59 PM
T-bucket23's Avatar
Wiki Edits: 26
You need to get back to the basics. You are in way to deep. I really didnt understand you pulling the heads when compression was normal and consistent across all cylinders.I would in this order
1,Plug all vacuum ports at the carb and see if it will run.
2,Turn the idle up to what ever it takes and take 1 plug wire off at a time to see if any make no difference.
3, Check fuel pressure with a gauge, don't guess.
4, Check voltage at the coil.
5, Check engine grounds
6 put a timing light on it at whatever you can get it to stay running at and see
what the reading is.
7 Vacuum gauge at whatever rpm it will stay running at, report the reading
and if it is steady.
get back with results
Chet
  #103 (permalink)
Old 04-19-2012, 04:22 PM
Gotta agree with Chet that there is some basic stuff that oughta be done. In addition to his list, though, I'd have to add checking the lift produced by the cam. Lifter faces should be convex.
Pat
  #104 (permalink)
Old 04-19-2012, 05:50 PM
T-bucket23's Avatar
Wiki Edits: 26
Pat
It could be an issue but I dont think it will give him the issue he has. Personally I think there is a huge vacuum leak that is preventing the carb from working at idle
Chet
  #105 (permalink)
Old 04-19-2012, 07:22 PM
I don't disagree. But it seems to me that concave lifters will destroy the lobes on a cam P.D.Q. Don't you think that the edge around the concave area will begin its damage by shaving the rear (highest) edge of the lobe? If he cuts apart the filter, that may tell the story. I'm not a pro wrench, but "Dad always said" those lifters need to be convex.
With some of the recent goings on here, I've gotta mention, absolutely no offense intended, but I do think it needs to be pursued.
PatM
Saginaw refuses to shift when hot Saito Transmission - Rearend 9 01-04-2011 07:06 PM
My wife refuses to support Bailouts!! Javelin360 Hotrodders' Lounge 14 06-21-2009 09:31 AM
Adjust Values Wayne Wagstaff Hotrodding Basics 4 05-14-2007 11:08 AM
392 Hemi Values FM2000 Engine 1 06-16-2004 12:25 PM
