Compression Values For Engine That Refuses To Run - Page 8 - Hot Rod Forum : Hotrodders Bulletin Board
  #106 (permalink)
Old 04-20-2012, 04:03 AM
malc's Avatar
Living At The Speed Of Life
Read all the comments and all seem in their way valid.
As I said before this happened over a period of time,
it wasīnt "yesterday runs okay, today itīs poop".
Vacuum leak, it would have to be a big one, intake has been off,
what ?, four times and it still exhibited the same symptoms.
Surely I canīt have reinstalled everything wrong that many times ?
So right here right now Iīm going for cam wear and I may not be able to check the cam lift until Monday/Tuesday.
The dial indicator I "got" yesterday wouldīnt measure the movement I needed so they have ordered up another, could be here today but I doubt it.
Iīm not starting it again until I have verified the state of the cam.
The last time I ran it the vac gauge showed 18-20 @ 2500rpm.
  #107 (permalink)
Old 04-20-2012, 07:25 AM
Flat cam wont prevent the engine from idling. Maybe cam walk.
You should be able to just fill the carb bowel through the vent tube and start the engine and it should idle until the bowel runs dry, usually 3-5 minutes.
  #108 (permalink)
Old 04-20-2012, 09:56 AM
T-bucket23's Avatar
Wiki Edits: 26
I don't understand your logic. This is not a cam, piston, cylinder etc issue. You either have a fuel system issue or an ignition system issue.
Vacuum leaks can be difficult to find sometimes. Why not take 10 minutes to plug all the vacuum lines at the carb or manifold and see if it runs better.
A bad cam would give you a miss at idle if it was flat but would most likely not get better at speed
Chet
  #109 (permalink)
Old 04-20-2012, 10:45 AM
malc's Avatar
Although my pump test failed to get gas flowing, the last time it ran the carb filled up nicely.
The MSD box is new, pickup in the distributor is new, wires are new, the rotor is pointing to number 1 @ 15šBTDC, set that today.
Where would there be a failure in the ignition to let the car run at 2500 but not idle, shuts down like every wire and feed line was chopped off, doesīnt linger, splutter, cough or spit ?
Iīll get it back on four wheels and do your cap the vacuum ports test.
Iīll take out the pump pushrod and measure it, itīs an ARP piece if I remember right.
  #110 (permalink)
Old 04-21-2012, 02:26 AM
thinwhiteduke's Avatar
Living In The Past
Listen to T-bucket 23
Still sounds like a vacuum leak to me.
Duke
  #111 (permalink)
Old 04-21-2012, 09:37 AM
malc's Avatar
Got the wheel seal done.
Plugged the four vac connections to the carb at the carb.
Same results, then with just the vac gauge connected, as before it
goes up with the revs not down as per the norm.
The motor is now back together as it was before this all began.
  #112 (permalink)
Old 04-21-2012, 02:54 PM
Living In The Past
So that means it's fixed???
Duke
  #113 (permalink)
Old 04-21-2012, 03:11 PM
malc's Avatar
No, itīs not fixed, "same results as before" means it runs with me peddling the gas, stop peddling and the engine dies.....immediately.
A vac gauge should go down as the revs go up.
The hunt will go on, valve lift check next.
  #114 (permalink)
Old 04-21-2012, 03:15 PM
T-bucket23's Avatar
Wiki Edits: 26
Not 100% true on the vacuum gauge. It will go down when you stab it but should come right back as the engine catches up. You carb needs vacuum to work at any speed. The fact that you need to pedal it is almost a sure sign that it is fuel / Vacuum related.
What was the reading at idle?
Chet
  #115 (permalink)
Old 04-21-2012, 03:20 PM
malc's Avatar
There is no idle, itīs 2000+ or nothing.
Plenty of fuel, the float bowls are at their set levels.
  #116 (permalink)
Old 04-21-2012, 03:27 PM
malc's Avatar
This analysis from the "Reading A Vac Gauge" link I was given earlier sums it up best;
Weak Valve Springs
When revving the engine hard, needle varies between 14 – 22 inches of mercury. As rpm increases, a wider variation occurs in needle movement.
Doesīnt include engine drops dead and will not idle.
  #117 (permalink)
Old 04-21-2012, 04:45 PM
If it has compression and spark, all thats lacking is fuel. Try dribbling fuel into the carb and see if it will idle. I drove a car home by filling a beer can with gas and punching a few holes in the bottom to meter the fuel a little.
Try yanking the distributor around and see if you can get it to just run.
This car doesnt have a lockup torque convertor does it?
  #118 (permalink)
Old 04-22-2012, 04:16 AM
malc's Avatar
Just ran it with the lockup convertor disconnected, no change.
I got it to run "better" by stuffing a towel in the rear barrels of the carb.
Got it to idle down to 100 lumpy rpms but it wouldīnt idle continuously without help from my right foot.
  #119 (permalink)
Old 04-22-2012, 06:59 AM
malc's Avatar
Should read 600 rpms.
  #120 (permalink)
Old 04-22-2012, 07:53 AM
refuses
i would remove gas cap if it runs u have a tank vent problem, also do u have catalytic converters on it? position your fuel reg. so u can see fuel pressure when it is running. and make sure your secondarys are not being held open by something.....steve
Saginaw refuses to shift when hot Saito Transmission - Rearend 9 01-04-2011 07:06 PM
My wife refuses to support Bailouts!! Javelin360 Hotrodders' Lounge 14 06-21-2009 09:31 AM
Adjust Values Wayne Wagstaff Hotrodding Basics 4 05-14-2007 11:08 AM
392 Hemi Values FM2000 Engine 1 06-16-2004 12:25 PM
