compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2008, 10:09 AM
novapower's Avatar
Last journal entry: out with the old
compressor
i am trying to run a 10 cfm tool @ 90 psi.i have a choice between two compressors.one is 15cm @ 90 with a 60 gallon tank and is a single stage pump max 135 psi.the other is 12.6 @ 90 psi but is a two stage pump up to 175 psi. with and 80 gallon tank.which would be better and why.no this is not just a math question i am going to buy compressor this week.i just do not want to buy the wrong one and then not be happy with it thanks
Old 12-30-2008, 11:08 AM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Lots of threads here about compressors. You might want to take a look at the "Knowledge Base" as well as doing a search in this forum. Why? The information you provided is not all that is needed to make a good evaluation and comparison.
Old 12-31-2008, 05:10 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
larger tank= longer time to refill tank and longer time between pump 'ons'.
smaller tank= opposite of above.
oil free compressor= no attention needed, just run it. Louder than a straightpiped musclecar, and it's not nearly as good sounding.
oil compressor= use non detergent oil in it, runs cooler and quieter than the above. Change oil every so often, which is a small price to pay for not going deaf.
Are you going to use the 175psi of air? 135 seems a lot more reasonable. My compressor (ancient old westinghouse motor, old commercial refridgeration pump, 1960s? speedaire tank) pumps to 80-90psi and I'm happy with it. Runs quiet, and refills in a couple of minutes. Stays cool as well after running for long durations (estimated 100% duty cycle) too!
Old 01-01-2009, 09:56 AM
302 Z28's Avatar
The dual stage compressors usually fair better during long duty cycle runs.
Vince
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 07:11 AM
Used compressor - rusty tank? Slipangle Garage - Tools 15 03-16-2012 09:51 AM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 01:18 PM
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 03:01 AM
air lines CARGUY Garage - Tools 96 11-16-2006 05:11 PM
