Compressor!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 11:21 PM
Compressor!!
I am told that my media blaster will require me to purchase a compressor that will run at a minimum of 9cfm @ 90psi , can anyone tell me if I should purchase a compressor that will max out at the minimum that is required or do I go with one that runs at a higher cfm? Appreciate all the help before.
Old 01-27-2011, 04:08 AM
Sales tactics (sales BS actually ) being what they are you can be sure a tool that is rated for air consumption will have the lowest numbers possible in order to make it look good, most air tools take considerably more than the usual optimistic ratings they have. Of course with air compressors just the opposite will be true for the same marketing reasons and most air compressors will be rated at quite a bit more than they will realistically produce so with that in mind plus a sensible working margin that "9 CFM" blaster will require a compressor of at least 12 to 14 CFM and even that will cut it close, even bigger would be better.
Old 01-27-2011, 10:23 AM
Thank you very much , I dont really understand all of the specs a compressor is labeled with but I will take your advice and look for a higher rated compressor. I know they get fairly or rather outrageously and ridiculously more expensive but I am very excited to start using my new blaster. Once again I appreciate your response and advice.
Old 01-27-2011, 11:51 AM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
I just laid out the framework for a new wiki article on this topic: Choosing a compressor; I know this is a common question here. The wiki article is currently just an organized list of headings and questions, but I'm sure it will be built gradually over time.
We do currently have an Air compressor silencer article, and I just put in a good bit of work on our Media blasting article, so this new article seems like a logical next step.
Eaton Compressor threatens to sue me over "Made in China" compressor post Jon Hotrodders' Lounge 190 03-06-2015 06:11 AM
Help with an Air Compressor randyinhouston Body - Exterior 4 09-05-2005 09:54 PM
should I buy this compressor? rlackey Garage - Tools 13 04-14-2005 01:27 AM
Compressor Help daveh Garage - Tools 23 01-20-2005 04:07 PM
Compressor Help daveh Body - Exterior 10 11-29-2004 08:08 AM
