Compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2004, 12:24 PM
New Member
Compressor
Well,since im going to be doing alot of work on my classic,and the number one tool in a garage/shop is a compressor, i went and bought one today. it is not a commercial unit but should do what i want,or at least i hope so,its all i could afford.
Campbell Hausfeld 7.0 HP 60 gal,11.8 scfm @ 40 psi/10.3 SCFM@ 90 psi, 135 psi max.
Will it cut the mustard?
Now all i have to do is get it into the shop and hooked up in a corner someplace.
Old 02-27-2004, 12:48 PM
poncho62's Avatar
Wiki Edits: 5
Should do quite well, better than what I use.
Ontario Rodders
Old 03-09-2004, 06:47 PM
jimk's Avatar
It is identical to my Husky.Uses the same parts.Mine works perfectly and I use it alot.
Old 03-10-2004, 06:10 AM
302 Z28's Avatar
Campbell Hausfeld, like several of the lower quality lines is notorious for rating their HP as peak. Your 7hp compressor (peak rated) is probably at best a 3hp under load. Try and get an honest hp rating. Peak hp is virtually useless in picking a compressor.
Vince
Old 03-10-2004, 12:38 PM
New Member
302/Z28, i think you are right,But,i have it hooked up now and have been useing it,it kicks on and runs more than i thought it should,But it recovers pretty fast,i have yet to run out of air and i have tried every air tool i have out,DA sander,air drill,die grinder. I wish i could have afforded a commercial type compressor but this one will just have to do,once i get all the body work done on my car and start sanding the entire car i should have a better idea of how it will do.
im going to look for a good gravity feed sprayer with a good recovery rate,im thinking (and correct me if im wrong) that a good gravity feed will use less air and have a higher volume output? it should keep up,or at least i hope so,otherwise ill be in trouble. im a learner in this new hobby,and i guessing that i can paint in sections,but that its not a good idea if i can get away from it?
Ive done alot of reading but thats all you get out of reading,the real learning will start when i get to actually a "hands on" situation.
Old 03-10-2004, 02:34 PM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
THere are also various grades of campbell hausfeld compressors from low to pro. I think their website has all the specs on it beyond horsepower, like air flow, and pressure etc. I personally have an old 10hp gas contractor grade compressor that will run a shop sand blaster all day... No down time with gas power. Some of the electrics have Duty cycles like welders, where it will run at this flow for this long then needs to stop.
Old 03-10-2004, 08:02 PM
302 Z28's Avatar
Actually, it is a common belief that HVLP guns use less air, it ain't necessarily so.
Vince
Old 03-11-2004, 07:28 PM
78514Ford's Avatar
New Member
compressors
Horsepower ratings don't really matter all you need to worry about is the cfm (cubic feet per minute) that the unit can deliver, also the larger the tank the more volume of air you will have whick will run tools longer between running cycles.
Old 03-11-2004, 08:26 PM
302 Z28's Avatar
Horsepower ratings don't matter?
Support for my argument about peak HP vs actual HP.
http://aircompressorsettlement.com/index.php3
In industry peak HP rating is not even mentioned, because it is a useless figure.
Vince
Old 03-24-2004, 09:13 AM
k2mooch's Avatar
I'm shopping for an electric compressor in the next few weeks. I want to use a die grinder to do some minor head porting, cutting of floorboards, and just blowing stuff around the garage for fun too.
My question is, what aspects of a compressor REALLY affect tool performance? What kind of CFM, PSI, and Gal tank should I be looking at for what I want to do?
Will 150 PSI max and 5.8SCFM @ 90 PSI keep the grinder spinning fast enough to not bind?
MoocH
