DO NOT under any circumstances attempt to adjust that regulator!!! You have a major regulator failure either due to a faulty/stuck regulator or wiring error. The pop-off did what it is supposed to and if it had not this could have been a major disaster, a tank explosion can be extremely violent. Before you attempt to run this thing again find out what is wrong and do not attempt to run that thing until you know. If it is new then use the warranty if not then you need to have someone qualified to look at it, make no mistake about it this can be very dangerous and can easily lead to a serious or even fatal accident and I am not exaggerating the dangers here!
