Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compressor Air Leaks
  #20 (permalink)
Old 01-18-2009, 11:31 AM
dinger's Avatar
dinger dinger is offline
Originally Posted by oldred
If that compressor is bleeding down to zero (or nearly so) every night you should find out why and stop it, probably a simple shut-off valve at the tank will do it.
What Red says, a valve would be a good way to stop this drain down. Another thought, if you have a few leaking hoses, these hoses probably aren't far from total failure. Blow a hose, have the compressor run continuously until someone shuts it down can't be a good thing. I shut mine down EVERY time I quit for the day. Thevalve would be good insurance for the forgetful.
Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
