Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - compressor blowing oil. HELP!
Old 03-20-2010, 12:03 PM
Montypierce Montypierce is offline
Oil in air?
Hi, the check valve sticking should not cause oil to get into the air. Oil blowing by the rings may cause that. Are you sure it wasn't water. A water filter is essential for any compressor when spraying paint of any kind. You should be able to drain the tank which you should do often anyway.
