Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Compressor Confusion
  #142 (permalink)
Old 12-22-2011, 08:22 AM
oldred oldred is offline
Originally Posted by Warhammer
I stumbled across this thread while doing some research for a compressor for my shop/garage and I'm glad I did. Lots of excellent info here, guys, thanks! However, I do have a question, probably a stupid one, but in a setup such as ToddMcF2002's what is the purpose for running elaborate drops to the other side of the small room, when you could just a easily connect a hose directly to the compressor (or better yet install a hose reel right above it on the wall) and avoid all that piping?
It's to remove water from the air, if you just run a hose directly from the compressor tank you will have a LOT of water in your air supply! By using all that metal pipe you remove most of this water because it will condense on the pipe walls and drain into the collection drops instead of exiting the end of the air hose and into your tools, paint (water drops in paint! ), etc. As the air comes from the tank during heavy use it will still be hot from the compression process so the moisture it contains will be in vapor form which will mostly just pass right through a moisture separator. The metal piping then acts as a heat exchanger that cools the air and allows the vapor to condense into liquid water that can be collected and drained, without this you could almost water your lawn with your air hose on a humid day! Well not actually that bad but you do get a lot of liquid water mixed with your air as the water vapor condenses as it expands and cools.
