Compressor Confusion - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-11-2011, 12:08 PM
Originally Posted by oldred
Yes you could buy two of the cheaper units but that is comparing Apples to Oranges. The HF compressor is a good home shop unit and the Husky/Kobalt/CH are marginal from a quality standpoint but the Quincy is a true industrial unit that will outlast all the others by a wide margin.
The 80 gallon tank would be good on a compressor of 20 CFM or so and between about 16 and 20 CFM it would just be a toss-up between it and a 60 gallon, less than 15 CFM and a 60 gallon would be a better choice.
Oldred, You are a great teacher. I learned allot in the last 24 hours from you. Thank you.
Now I need to re-think if I need the extra for the extra money. China=bad US=good. So need think budget more.
  #32 (permalink)
Old 04-11-2011, 02:26 PM
I am looking at the Harbor Freight unit as well. I'm talking to a mover about picking it up since HF offers no services. They were pretty clear that if anything goes wrong I have to bring it back to the store. That's a pretty big issue for me, not sure it is something I want to deal with...
  #33 (permalink)
Old 04-14-2011, 09:37 PM
Oldred,
I am thinking of the Quincy 60 gallon 5hp 1310 RPM 15.2 ($1,399) or the 80 Gallon 5hp 942 RPM 17.2 machine ($1,999). Which one is better for the money and would be better on electric in the long run.
Looking to run some 2 nail guns at the same time. Airsander and nail gun. Not sure what else no more then 2 devices at the same time. The sander is always wiping out the compressors I have now.
  #34 (permalink)
Old 04-15-2011, 08:52 AM
Depending on which sander and how much CFM it needs (the manufacturer ratings are usually so absurd they don't mean much) the 15+ CFM might still run out of air after a while but running that Quincy continuously will not hurt it, with an air hungry tool like a sander even the 17+ CFM might not keep up over a long period. With either compressor I doubt you will be disappointed since I am not talking about running low on air after only a minute or so like the cheap compressors that CLAIM similar CFM ratings and the larger one might even out-run the sander, 15+ CFM is not at all bad for a home shop and from the Quincy (unlike the cheapo compressors) you can count on actually getting what it is rated for! The nail gun(s) are going to be a non-issue and if that sander is all you are concerned about then 15+ CFM is probably going to be just fine for you unless you mean you will be running more than one at a time. As far as power consumption I would think the larger outfit would be better in that respect because it has a larger more efficient pump, there is no question that 17+ CFM outfit is the more desirable of the two if the extra cost is not a problem. If just running that one sander and a couple of nail guns is what you will be doing the smaller one should fill the bill nicely unless the sander is going to run a big percentage of the time, one thing is for sure you will never regret having a compressor that is too big but you will always regret having one too small!
  #35 (permalink)
Old 04-15-2011, 09:02 AM
So I would think the larger fills quicker then the small. So the power used would be comparable or negligible.? What I don't want to do is buy a v8 when a v6 is less gas mileage. I am assuming that the 5hp is my v6 and it is the same on both compressors just the compressor piece is different and runs at different rpm's.
  #36 (permalink)
Old 04-15-2011, 09:36 AM
Just because a motor has a power rating of 5 HP does not mean it is always making that much power. Basically the rating means it has the potential to make that much power and draw a proportional amount of electricity to the power it actually makes, this is dependent on the load applied. The larger compressor would draw more power while running but that will be partially off-set by the fact the bigger slower turning pump will be more efficient and make more air per watt of power consumed. The power cost differences between these two compressors will be small and any savings would probably be with the bigger one but only over a long period, it actually would be negligible unless you are running a full time multi-duty shop.
  #37 (permalink)
Old 04-15-2011, 02:40 PM
I found a local hobbyist who wants to sell me a rebuilt compressor and used air heater for $700.
Its a 3HP motor on my choice of a 60 or an 80 tank. Price includes delivery and placement (with my help of course). The tank is big for the motor but he says he can paint (low CFM) on it and DA.
Prolonged die grinding was the real limitation he's claiming. I'm going to get this wrong name wise, but I think he said the motor was a "Wayne 6200". Thoughts?
  #38 (permalink)
Old 04-15-2011, 03:08 PM
Jon's Avatar
Jon Jon is offline
Hotrodders.com Administrator
Wiki Edits: 7314
These new Knowledge Base categories may be helpful:
Air Compressors
Air Compressor Suppliers
  #39 (permalink)
Old 04-15-2011, 08:26 PM
Originally Posted by ToddMcF2002
I found a local hobbyist who wants to sell me a rebuilt compressor and used [AIR HEATER] for $700.
Air heater? Are you sure he didn't mean air cooler?
As far as the tank is concerned that would depend on the CFM but this sounds like a home assembled outfit and I imagine the CFM is unknown. With only 3 HP I seriously doubt the CFM is high enough to warrant the use of an 80 gallon tank and in all likelihood the 60 gallon would be the better choice, in fact I can just about guarantee the 60 gallon would be better suited! The 80 gallon probably will work without any major problems but there certainly would be no advantage to using it unless it is in better condition, I would strongly suggest using the 60 gallon but look them over and take the one that looks to be in the best condition.
BTW, from the description of the set-up that price sounds waaay high to me!
  #40 (permalink)
Old 04-16-2011, 04:58 AM
Thanks oldred and yes, air cooler. I need to understand better the end to end system. I thought 30ft of tubing with water traps / filter was enough to cool and filter the air but this guy insisted the little refrigerator cooler along with the filter was a must have.
I did some digging and the Wayne 6200 is 1950-60 vintage. Great for its day apparently and you can still find parts.
As far as price, I am tempted by this purely because of the low overall price commitment for an end to end system (minus piping) and the fact that if any individual component goes I can replace just that. I'm not convinced though and perhaps the price is too high like you say.
  #41 (permalink)
Old 04-16-2011, 09:45 AM
Those old compressors can be like old (classic) cars and to some of us they can be a fun hobby but for everyday use by someone not familiar with them they can be a lot of trouble. Something else I should have mentioned earlier is those tanks could be a major headache if they too are that old. You have no way of knowing the condition and having them hydro-pressure tested is a MUST if you want to do this safely! An old tank can be a time bomb and an exploding 60 or 80 gallon tank could easily destroy a garage and do serious personal harm, fortunately most of the time they just spring a leak and catastrophic failure is rare but it DOES happen sometimes! Don't take anyone's word that is a tank is ok unless it has been hydo-tested because no matter what they say they just simply don't know, that old line that the old tanks are better built and will last forever is BS. I strongly suggest thinking this over and consider all the problems you are likely to encounter as an "antique" compressor owner because in all probability you will encounter these problems.
One more note about the tanks, look them over thoroughly and look for repairs of ANY kind especially around factory welds. If there have been any repairs or ANY welding on the tank that was not done at the factory then don't use the tank under any circumstances. A tank that has been welded on for repair or modification is extremely dangerous even if it is just a small weld, if either tank has been "repaired" I strongly suggest not using it. I am not exaggerating the dangers of an exploding tank and I have seen it personally twice, once time was when a 40 gallon tank took off the cab of a DM800 Mack truck and another blew a hole in a garage wall big enough to drive a truck through-trust me on this it does happen!
  #42 (permalink)
Old 04-16-2011, 12:15 PM
I have gotten allot of education on compressors the last few days. Glad I found this forum (thanks oldred) and a few others off of posts in this fourm. These are some of the ones I found especially helpful outside of here.
http://www.oldsmobility.com/oldsmo/v...ic.php?f=8&t=5
http://www.tptools.com/StaticText/ai...ng-diagram.pdf
http://www.tptools.com/StaticText/AirConsum.aspx
http://www.camaros.net/forums/showthread.php?t=90894
I also went to HF to get a paint shaker (looks cool might mix paint for me). But, I looked at thier compressors again. That whole Chinese junk thing worries me. They have one that looks good but, not sure. $799. See pictures below. Not sure if this one is the junk one.
I am also still thinking of the Quincy at $1399 http://www.northerntool.com/shop/too...0475_200350475
As for the compressors I am still wobbling at $799 vs $1399 Wondering if I get the $799 one and next year when cash is more flush buying the quincy one maybe even going up to 7.5 Quincy and selling the the HF one for $600 I am sure people would jump all over that.
So my question is what else do I need that I am not thinking about. I think I need a water separator. I am going to just put in compressor, electrify it and want to plug in with a hose. fancy stuff will come later. So I need something to separate the water next to it right? Where should I get that from.? Is that a whole other week of research?
  #43 (permalink)
Old 04-16-2011, 01:48 PM
We have been trying to point out that the US General compressor at HF is NOT Chinese and it is not junk. That one you have in the pics is an American built compressor except for the very good quality Italian built pump. That is a good compressor and the fact it is from HF means little as it is actually a rebadged Belaire. That US General is a good home shop outfit and is hard to beat for the money but of course the Quincy being more of an industrial type unit (and priced accordingly) is going to last longer and will have a heavier duty cycle. It all depends on the kind of service you need, if you are only looking at home shop needs the the US General will perform well and last a while but if you need full time service 8 to 10 hours a day 5 or 6 days a week then the Quincy is the obvious choice.
Also if you only need home shop service and can spend the extra money then you can count on that Quincy for many years, maybe a lifetime.
  #44 (permalink)
Old 04-16-2011, 02:03 PM
OK. Glad I posted the pic's. Just saved myself $600 bucks in the short run (I know in the long run the Quincy is the better investment). The guy at HF did mention that was an American made as far as mostly assembled here in the USA. Some of the innards could be Chinese he did comment.
I am definitely leaning way farther toward the HF one now as my starter big boy compressor. Wife is also leaning toward that price over the $1400. Since I will most likely need more pieces and have not accounted for that. She knows me.
So what else should I get to run it.? To plug in a tool into that thing I should have _____ minimum. (ie water separator etc regulator etc.) Not going to do any painting just sanding nail gunning etc.
I build bee hives and run nail guns and sanders mostly. Will use it for other stuff I am sure later and will add in that whole water cooling system I read about when I get the garage/shop built. If you ever want to start bee keeping come over to our forum http://www.beesource.com/forums/index.php
  #45 (permalink)
Old 04-16-2011, 02:46 PM
I don't know what he means about "Chinese innards" and I suppose almost nothing is 100% USA made anymore but the US General/Belaire is far more than just "assembled" in the USA. That thing is about as American as you are going to find anywhere and I have to admit I was very much surprised, and impressed, when I learned they were indeed a real Belaire product and not just a stripped down unit based on an AMERICAN built Belaire tank.
This is where that US General compressor comes from and it is not Chinese, scroll down the page and you will find the US General you are looking at but it will be a different color with a different name.
www.asedeals.com/air_compressors_copy.html
I just visited your site and yes I am very interested, I will definitely be checking it out.
Cam Confusion glduke Engine 8 09-15-2010 10:01 PM
t5 confusion chevy305ranger Transmission - Rearend 4 05-12-2009 07:11 PM
Cam confusion??? riflegunbuilder Engine 2 09-19-2005 04:08 PM
car confusion ChevelleSS_LS6 Hotrodders' Lounge 1 06-24-2005 05:47 PM
Q-Jet Confusion adryan16 Engine 10 10-16-2004 03:24 PM
