It's three phase! 3 phase electric is not usually found in home garages. In order to get 3 phase you'll end up spending way more that that compressor is even worth. Not to mention 3 phase motors are extremely expensive to run.
What I did was found a 60 gallon Speedaire at a garage sale "cheap". After I got it home I found that the cylinder head had some damage to it and it's super expensive for replacement parts. So I purchased an Eaton Head unit and bolted her up. I basically have a brand new compressor for $300. Not exactly super heavy duty, but it's at least rated for continuous use, and it's quiet. Look for a "single phase" compressor on Craigslist or at garage sales, double check the tank for excessive water or rust. Slap some new parts on her and your good to go! As long as the tank is good, every thing else can be replaced with higher quality components.
I completely missed that 3 phase requirement, that's enough by itself to pass on it!
Yes that's what it means, you can run it on either 220 or 440 volts BUT it must be three phase, you definitely won't have three phase power available at home. Generally three phase motors can be run on single phase power with the addition of a phase converter but running compressors on such a set-up is not really a good idea. |
Three phase equipment is not at all expensive to run compared to single phase. Granted hooking up tp three phase power can be really expensive since it is for commercial use but three phase motors are very economical to run.
air compressor
any feedback on a Ingersoll Rand 60 gallon? Northern tool has it on sale for $850 right now, free shipping, if you buy the start up pack for an extra $80 it extends the warranty an additional year...
Key Specs CFM at 90 PSI 18.1 Max. PSI 135 Volts 230 Amps 22.5 HP 5 Air Tank Size (gal.) 60 Tank Description Vertical Pump Single-stage, oil-lubricated, belt-driven Air Outlet Size (in.) 1/2 Portable or Stationary Stationary Dimensions L x W x H (in.) 20 x 30 x 71 Manufacturer Warranty 12 months parts / 12 months labor Ship Weight 450.0 lbs |
You evidently have not bothered to read many posts since that thing has been discussed several times lately, even in this thread! Basically there are several points of interest, first that 18.1 CFM rating is just flat out ridiculous and the real compressor dealers like Compressors Direct rate them at a more believable 15+ and that's being generous. Same compressor but from a compressor dealer, http://www.aircompressorsdirect.com/...ssor/p689.html Next and even more important is they have a KNOWN motor problem that has been discussed here and on several other sites, in fact we have one thread here that has four different owners complaining about burned out motors on these things on low time compressors-four of them at the same time in one thread! Also whether it matters to you or not they are not industrial Ingersol Rand compressors, they are made by Shanghai Xinran Compressor Co., Ltd in China and imported by IR. |
ingersoll rand
I read thru over 100 of them, lol, but didn't come across those comments.
thanks for the info! |
I'm sure not every IR of this model has suffered motor problems, obviously most of them don't, but there have been enough complaints here and on some other sites to safely say it is a very common problem and worth mentioning. Another member posted that he believes the problem may be using wire that's too small and maybe so but the problem does not seem to extend to other makes, other brands suffer motor failures also but the IR model in particular sure seems to come up a lot! Doing a google search on this problem is quite revealing so it is well documented and whenever someone asks about them it is only fair to point this out.
http://www.hotrodders.com/forum/comp...+rand+warranty EDIT: I just scanned through that thread to verify the number of cases of burned out motors and I was wrong it was not four cases in that one thread, looks like it was five! Last edited by oldred; 06-15-2011 at 06:54 PM. |
Well the motor will draw what the motor needs to draw, so I would think the wire would just melt before any harm came of the motor.
And yes, 10 gauge or whatever they use stock (I can't remember) should be more than sufficient. |
I would avoid Newer IR compressors at all cost unless you get the screw type which is really expensive.
| Recent Garage - Tools posts with photos |
| Cam Confusion | glduke | Engine | 8 | 09-15-2010 10:01 PM |
| t5 confusion | chevy305ranger | Transmission - Rearend | 4 | 05-12-2009 07:11 PM |
| Cam confusion??? | riflegunbuilder | Engine | 2 | 09-19-2005 04:08 PM |
| car confusion | ChevelleSS_LS6 | Hotrodders' Lounge | 1 | 06-24-2005 05:47 PM |
| Q-Jet Confusion | adryan16 | Engine | 10 | 10-16-2004 03:24 PM |
