Compressor Electrical Connection - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2004, 10:54 AM
Im trying to have an idea!
Well as some of you may know that I have been getting my compressor piping up for a couple of weeks.
Yesterday was the day I was going to break in the compressor before i connected the main line to it.
I did as the manual read for start up, I went to start the thing...and nothing. the darn thing did not even
make a noise. I started to think it may be a dud, but wanted to give the machine a chance. So i go back
to see if i screwed up electrically. I have the 20amp breaker in place, have two hots, and a ground in place,
put a test light to the hot side of the compressor (off my cord to outlet), bright as day. Take off place on
motor where power enters, put the switch to auto position, put test light on, once again it lite up. Am I missing
something here or did i get a dud.
also see attached
here be the compressor again.
http://www.harborfreight.com/cpi/cta...emnumber=32357
Old 07-26-2004, 10:55 AM
Another attachment
Old 07-26-2004, 12:14 PM
I picked up a volt tester at lowes and tested the leads in the motor to switch, and from ground to lead one I got 120v.
from ground to lead two I got 120v.
I am thinking it is a bad motor.
when i went to test it, and turned on power, i can smell somthing getting hot in the motor.
any suggestions.
tonight im going to take the compressor back for an exchange.
Old 07-26-2004, 04:24 PM
well the problem was....
was...
me staring at something that did not slap me on my face.
the breaker needed to be placed one space over...so that way it would make a 2 pole connection....
yes you may laugh....
Old 08-16-2004, 10:01 PM
Old enough to know better
Remember, with 240 volt, you measure from hot to hot! Nothing should actually be referenced to the ground wire. It is there for safety only.
I bet it runs better now that is has some volts to eat.
Old 08-17-2004, 07:40 AM
I think i was just having a brain fart, but my mistake is everones fix...i hope.
