We're winning the case!
Hotrodders Bulletin Board > Tech Help > Garage - Tools
  #1
Old 07-08-2004, 07:42 PM
Bluepen's Avatar
Bluepen Bluepen is offline
Just a firefighter
Bluepen's barnstar
Wiki editor
Last wiki edit: How to title a hot rod
Wiki Edits: 2
Compressor groans??
I've got a Husky 60 gal compressor and today while I was using it painting some parts for my truck it started to groan when ever I was flowing air. I checked the valves and they were open all the way, stopped and drained the tank of water, very little found. Don't know why it did that, anyone with an idea??
Thanks
David
Old 07-15-2004, 08:05 PM
Alecigio Alecigio is offline
You should check the oil level in it, it might get a little low, or maybe there is no oil at all... It happened to me last year, I was using the compressor and one day it stopped and I needed to change the motor on it... My father never put oil in it and he had it since at least 20 years . Another problem I can think of is there might be a loose screw that is making everything shake or the strap on it is not aligned correctly. Good luck with it.
Old 01-18-2005, 09:20 AM
ranger28 ranger28 is offline
New Member
husky quality
I am considering purchasing a husky 60 gallon compressor. what do you think of the quality? I will use it for running cut-off wheels and the small angle grinders. would it run those sufficiently? I haven't seen any actual cfm ratings for it just the cfm ratings husky puts on the tank.
any info. would be much appreciated, thanks.
Old 01-18-2005, 03:08 PM
1ownerT's Avatar
1ownerT 1ownerT is offline
1ownerT's barnstar
Wiki editor
Last wiki edit: Building a new shop
Wiki Edits: 2
Re: husky quality
I second that. I do like that it has a cast iron pump.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
