I'm in the same boat as you are. Looking to spend around $500 for a two stage. I saw the Sears also but I don't want a non belt driven compressor. Too noisy. The closest I could find so far is at Lowes. Two stage Camble Hausfield (sp?) $627. If anyone knows of a supplier that sells a two stage, belt driven for something closer to $500 I would be interested also. I don't want to take a chance with EBay either.
i got a craftsman 60 cal 7hp single stage compressor for doing painting and bodywork. the bodywork tools i could have used some more cfm for as you need to have it catch up, but for painting itself the compressor is more than enough.
can't remember if mine was 599 or 699 canadian |
I would not buy a direct drive compressor for any kind of serious use.
If you are ready to buy right now, you might want to check out Sears Friday morning. My son tells me they are having a major Christmas kickoff sale for 5 hours in the morning. I think it is a nation-wide deal. You might also want to check out http://www.eatoncompressor.com/page/page/504413.htm They sell what seem to be some heavy duty compressors at pretty good prices. |
I debated this same question when I was ready to buy a new compressor. The sears compressors had a good price, but the CFM was not that great and I did not want a direct drive pump. Looked at some Coleman compressors that had a good price, but didn't look like they were very good quality (foam air filter, etc). Also think about how long it will last. Think seriously about the ingersol-rand 60 gal. You can get this through sears. Very good quality compressor with good CFM. Only problem is that it is $1000. I debated and spent the $1000 since it is something that I will have for a lot of years and it can be repaired. It will also handle all the air tools that you have or will have and you won't regret it 6 months down the road. my 2c
I went thru the same thought process on my compressor 2 years ago. I ended up with a DeVillbiss 6.5 HP single stage with 60 gal tank.. I use for re-doing my 52 chevy pick-up(painting,grinding,sandblasting, plasma cutter et..etc. Horse power, cfm and tank size are part of the equation....don't forget DUTY CYCLE( time on versus time off for cooling).....especially if you decide to go with borderline sizing...When I am doing prolonged work, I have a external fan blowing on the compressor. for additional cooling. I wish now that I would have spent the extra for dual stage, bigger compressor.........
You will almost certainly never regret buying a good compressor. I got a good deal on an industrial duty used 2 stage and, every time I use air, I'm thankful I got a good compressor. I've found I use air tools more and more. They are fast, light, and safe - even in a rainstorm (yeah, impact wrench and flat tire!)
I just picked up a new one a few weeks ago. I found an Ingersoll model SS5N5 at Tractor Supply Co. for $750. It is a single stage, 80 gal, 11.8hp peak, 5hp running (the important one) and puts out 18.1 cfm at 90. 100% duty cycle with synthetic oil. This is the same compressor as the SS5L5 but with an 80 gal tank. I started looking at the units for under or around $500 and I am so glad that I stepped up to this one. I used it this weekend to pump about 200lbs of sand through a siphon feed sandblaster, and the compressor was only running at about 50-60% duty with me continually sandblasting. It is unbelievably quiet compared to the oil free units or my beat down 25 year old sears unit. Keep in mind your power requirements too; the one that I got pulls 22.5 Amps full load on a 220V circuit. I don’t know if you have a Tractor Supply in your area, but I think that they may be doing a 3 months 0% interest on a TSC credit card. Anyway, that is my 2 cents worth.
I was in the same boat as you and had no luck finding a quality compressor in the $500 range. I saved up and bought a 60 gal, 5hp, 16cfm at 175psi quincy compressor for around $900. I bought it from harbor freight but it shipped directly from Quincy.
That was the best tool purchase I ever bought. You can use a DA or any other type of sander all day without even dropping below 150psi. I still haven't tried my sandblaster with it yet but it should work pretty good. kev |
