Compressor ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2005, 01:38 PM
Compressor ID
I have a chance to pick up an IR T10560V1 compressor fairly cheap but I cant find any specs on that model number. Anyone know about this compressor, or where I could find info?
Thanks
Old 02-18-2005, 08:22 PM
When I was looking at a used IR comressor, I called their customer service and got excellent response. I had the model and serial in hand and they told me everything about the unit. They also informed me the unit I was looking at was three phase, and how much a single phase motor to replace it would cost. I got their number from their WWW site.
Hope this helps.
SM
Old 02-18-2005, 08:45 PM
Ad- that looks like a serial no. I may be wrong, but if you have a different model no. I will try and find it for you in one of my manuals.
Old 02-19-2005, 08:53 AM
Thanks guys I called IR got its a 5hp 60gal single stage putting out 12.5 cfm @ 40 psi and 11 cfm @ 90 psi. It seems like that would be as small as I could go to run an hvlp gun or da sanders efficently. I made the guy an offer and hes not asking much so if he takes my offer Ill pick it up, but whats everyones opinion on those numbers. I made the too small mistake once, but this could be a hell of a deal.
Old 02-19-2005, 12:38 PM
ok Im gonna pick up this compressor tonight Im giving him $200 for it supposedly the only problem is the moisture release valve leaks a little should be any easy fix. What do you guys think?
